error loading new ios
mathiasivn
Level 2
Level 2
hi there
i upgraded my catlyst 6506 ios from c6sup22-dsv-mz.121-23.E2.bin to s222-ipservices_wan-mz.122-18.SXF7.bin
but the swicth has crashed nwo getin into rommon
the error
System Bo otstrap, Version 7.1(1)
Copyright (c) 19 94-20 01 by cisco Systems, Inc.
c6k_sup2 processor with 131072 Kbytes of main memory
Autoboot executing command: "boot disk0:s222-ipservices_wan-mz.122-18.SXF7.bin"
Self extracting the image... [OK]
Self decompressing the image : ############################################################################### [OK]
Compiled Thu 23-Nov-06 02:21 by kellythw
Image text-base: 0x40101040, data-base: 0x41108000
00:00:04: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
00:00:08: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:08: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
System Bo otstrap, Version 12.1(1 1r)E1, RELEASE SOFTWARE (fc1)
TAC Sup port: ht tp:/ /w w w.cisco.com/tac
Copyright (c) 20 02 by cisco Systems, Inc.
Cat6k-MSFC2 platform with 131072 Kbytes of main memory
Download Start
Download Completed! Booting the image.
Self decompressing the image : ####################################################### [OK]
%Software-forced reload
Breakpoint exception, CPU signal 23, PC = 0x41B4F624
=-Traceback= 41B4F624 41B4D5B0 4191E060 4191E08C 418046EC 41840EB8 41837288 418372E0 407442BC 40744FA4 41760D20 41760B3C 418BF780 418BC6A4 418BC8C0 41B41D8C
$0 : 00000000, AT : 1E020000, v0 : 43960000, v1 : 00000070
a0 : 44B78F40, a1 : 4398D54C, a2 : 00000005, a3 : FFFFFFFC
t0 : 0000000D, t1 : 00000000, t2 : 0000013E, t3 : 00000002
t4 : 4398D4F8, t5 : 00000000, t6 : 0000DC26, t7 : 4398D4F0
s0 : 00000000, s1 : 42BC0000, s2 : 43F15F20, s3 : 073B55C8
s4 : 44ACFB10, s5 : 44A4EC98, s6 : 00000040, s7 : 43350000
t8 : 4398D4D4, t9 : 00000005, k0 : 00000000, k1 : 00000000
gp : 42BFDF40, sp : 4398D580, s8 : 00000000, ra : 41B4D5B0
EPC : 41B4F624, ErrorEPC : 20600610, SREG : 3401F103
MDLO : 33333373, MDHI : 000000FF, BadVaddr : DFDDFFFE
CacheErr : 80000000, DErrAddr0 : 1E02000C, DErrAddr1 : 04B78F40
Cause 00000024 (Code 0x9): Breakpoint exception
Writing crashinfo to bootflash:crashinfo_20070113-153918
=== Flushing messages (15:39:18 UTC Sat Jan 13 2007) ===
Buffered messages:
Queued messages:
00:00:50: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:47: RP: Currently running ROMMON from S (Gold) region
00:00:50: %CPU_MONITOR-3-PEER_EXCEPTION: CPU_MONITOR peer has failed due to exception , reset by [1/1]
*** System received a Software forced crash ***
signal= 0x17, code= 0x43300000, context= 0x43967184
PC = 0x41b42394, Cause Reg = 0x3020, Status Reg = 0x34018002
rommon 1 >
00:00:51: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:51: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:51: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
signal= 0x17, code= 0x41df0000, context= 0x41e17e74
PC = 0x402cf86c, Cause = 0x1820, Status Reg = 0x34018002
help is realy appricated ..
how do i revert it back .
cheers
5 Replies 5
Hi there,
I don't thik that tftpdnld works for Catalyst 6K, i think that you have to go for xmodem or use the boot image to download the image using tftp (which might not be an option here), or as a last resort if you have a platform utlilzing the same file system use it to put the old image on a PCMCIA card and boot your switch with it (actually this works great).
HTH.
Mohammed.
copied old image to PCMCIA and in ROMMON > boot disk0:
its comes up . but when i restart it goes to again rommon MODE .
I did changed Boot parameter . but no luck ..
plese guide me what excat command i have to issue or change
Cheers
Hi there,
Its that simple, after booting it up from the rommon issue the following:
config-register 0x2102
boot system disk0:
write memory
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
regards,
Mohammed.
OHHHH How can i forget conf reg .. tx
