error log cisco 1841
VaziaysLA5
I have cisco 1841 ios 12.4 (7)
fall tunnels
then in the log message
%EM_FPGA-1-FPGA_RING_FULL: FPGA buffer descripter is full
eliminated only reboot
how to fix it
7 Replies 7
jawad-mukhtar
Level 4
Level 4
%EM_FPGA  error codes and seems to be related with encryption or  along those lines, I suggest if you have smarnet to open up TAC case as  there is not much information provided in more depth.
Jawad
InayathUlla Sharieff
Hi Anton,
%EM_FPGA-1-FPGA_RING_FULL: FPGA buffer descriptor is full
The error message happen when the incoming packets rate to the FPGA-crypto
engine is faster than the capability that it can handle. As a result, there
is no more FPGA-crypto buffer descriptor and errors will display.
Please configure the following command on the router (in config mode) to
take care of any fragmentation issue with IPSEC:
crypto ipsec df-bit clear
Not sure what ios you are running. Please have a look at the following bug:
CSCei00807 and if you happen to run the code which is affected with this bug then do consider upgrading the firmware.
Inayath
*Plz rate the usefull posts.
Thanks for answers
today evening
I will correct the configuration
Hi Anton,
Please do let me know how it went.
Inayath
Thanks for the help, but it  does not fix my problem....
Hi Anton,
Its time for you to upgrade the firmware. The issue is due to bug.(CSCei00807)
Below are the releases which have the bug fixed.
12.4(24.5.2)PIC1,12.4(22.3.4)PIC1,12.4(2.9)T
12.4(2.10)T,12.4(2.10)PI2a,12.4(2)T1
Inayath
excuse me
I corrected
the problem was in the wrong routing
