error message "Bad magic number in chunk header" on 3845
rogerloo
Beginner
Beginner
hello, i just recently swapped out a suspect 2mft-t1/e1 vwic on a 3845. Now i'm getting messages like this
.Jun 1 17:52:23.792: %SYS-2-CHUNKBADMAGIC: Bad magic number in chunk header, ch
-Process= "<interrupt level>", ipl= 4
-Traceback= 0x60AEFB68 0x60037E28 0x602AF38C 0x606D6448 0x606D7324 0x606D0EE0 0x
every minute or two. what is this referring to? and should I rma the RMA'd vwic?
thanks
rl
mchin345
Frequent Contributor
Error Message
%SYS-2-CHUNKBADMAGIC : Bad magic number in chunk header, chunk [hex] data [hex] chunkmagic [hex] chunk_freemagic [hex]
Explanation : An inconsistency was detected while the chunk memory pool was being managed. It is likely that this is a software error, but there could be a hardware memory problem.
Recommended Action : Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl.
I'm having the same problem. 3845 IOS 12.3 originally. TAC said there was a bug and upgrade to 12.4.1(a). Didn't fix the problem. They RMA'd the hardware. No fix there either.
TAC is still working on it.
Recognize Your Peers
