Error on 1921 boot up
TRACY HARTMANN
Level 4
Level 4
I purchased several 1921 routers and the last two I setup get the following error during bootup:
%SYS-6-READ_BOOTFILE_FAIL: tftp://255.255.255.255/1:aaa1386.bin No usable interfaces.
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
%MAINBOARD_GE-3-SHUTDOWN: FPA PKT pool holding 512 particles.boot of "1:aaa1386.
bin" using boot helper "usbflash0:c1900-universalk9-mz.SPA.151-4.M4.bin" failed
error returned: No usable interfaces
loadprog: error - on file open
boot: cannot load "1:aaa1386.bin"
The router moves on and eventuall comes up fine and is operational.  Does anyone know what this error is an if I can get rid of it?
5 Replies 5
paolo bevilacqua
Check boot statement in configuration.
Yes I did try to  remove the statement in the boot start section but it will not remove.
Try again and post details.
I finally got it out.  After going into Config t I was typing boot-start-marker and then no 1:aaa1386.bin.  It would take the statement but would not remove the line.   Then I tried just doing no 1:aaa1386.bin from the Global config and it took it.
You're welcome, please remember to rate useful posts clicking on the stars below.
