Error on Cisco 877 router
noobieee7
I am having this error on my Cisco 877 router. I have swapped a fresh new one but it is still giving me the same error.
Apr 24 21:20:22: esw_dtc_ltc4258_reg_write: no acknowlege from POE
Apr 24 21:20:22: esw_mrvl_pdc_hardware_config failed on slot 0/0
Apr 24 21:20:24: esw_dtc_ltc4258_reg_write: no acknowlege from POE
Apr 24 21:20:24: esw_mrvl_pdc_hardware_config failed on slot 0/0
Apr 24 21:20:49: esw_dtc_ltc4258_reg_write: no acknowlege from POE
Apr 24 21:20:49: esw_mrvl_pdc_hardware_config failed on slot 0/0
Apr 24 21:20:51: esw_dtc_ltc4258_reg_write: no acknowlege from POE
Apr 24 21:20:51: esw_mrvl_pdc_hardware_config failed on slot 0/0
Any advise?
Do you have this module installed on the router -
800-ILPM-4
4 port 802.3af capable Inline power module for 870 routers
If not then this is a cosmetic issue.
BUG - CSCsd68389
870 displays POE message unexpectedly when no POE module installed
Alternate Headline: 870 displays POE message unexpectedly when no POE module installed
Symptom:
A Cisco 871W may display a log message that the POE module is not responding even
though there isn't a POE module installed.
An example is:
Conditions:
This may show up randomly in the logs. It's a cosmetic issue that does not
affect the operation of the device.
Workaround:
None.
If you don't have the module please ignore these messages.
-> Sushil
