Evaluation License vs RTU
alshamlan
Dear,
I have CISCO887VA-M-K9 router and I have activated the eavluation advipservices license on it as below:
ROUTER#show license feature
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
advipservices            yes          yes         no             yes      yes
ROUTER#show license
Index 1 Feature: advipservices
        Period left: 8  weeks 0  day
        Period Used: 3  days 11 hours
        License Type: EvalRightToUse
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Low
My Quation :
1- what it will happen if the evaluation period expired and licensed converted to RTU license? Am I going to lost the configuration done on the router?
2- If the RTU licese is only a paper license for legal? or it has to be activated on order to maintan activation of the advipservices
amsodhi
Looking at the output, I would say that you are running temporary IPSERVICES license on your 800 series. Temporary licenses are used for evaluating new capabilities or in emergency situations. A temporary license allows a feature set to be used for 60 days of actual usage. When the 60-day period expires, the device will continue to operate normally until reloaded. After the reload, the device will default to the original functionality before the temporary license was enabled.
-Amant
Dont forget to rate the answer :-)
-Amant
Thanks Amant for your email.
Will be able to reactivate the licensed again after 60 days expiration temporary for lab testing?
I don’t think that you can reactivate temporary license again once it’s expired. You may open TAC case with the licensing team to get the permanent license.
-Amant
-Amant
