EVN route-replication problem
blue phoenix
evn topology
Hi all,
I just need someone to point me to a link that shows the correct syntax on route-replication using filter options.  It seems i can't replicate what is being done on this cco site:
http://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/200669-Configure-Easy-Virtual-Network-with-EIGR.html
I will upload the configs, and outputs both from RIB and CEF tables for you to see what I have done and probably slap my hand since I missed something so simple 😞
Using the route-replicate from vrf [VRF NAME] unicast all works though...
I have tried this on a virtual lab using both IOL(15.5) and csr1000v(Version 15.5(1)S1)
Maybe it's a syntax issue?
Please see attached configs and show outputs and let me know your thoughts...The second file is using unicast all and the routes are seen...
Georg Pauwen
which VRF is the route filter applied to ? Post the full configs of ISP1 and ISP2.
The normal behaviour should be BLUE can't access GREEN and vise-versa, however both of them should be able to access shared service SERVER.
route replicate from vrf BLUE|GREEN|SERVER unicast all works and the behaviour above is achieved.
route-replicate from vrf BLUE|GREEN|SERVER unicast eigrp [BUE|GREEN|SERVER autonomous system number] route-map [name], doesn't work at all...
However this one works
route-replicate from vrf BLUE|GREEN|SERVER unicast all route-map [BLUE|GREEN|SERVER]
Please see attachment.
