Excessive collision in the Router
UCBNOCWAN
Hi All in Router i am the getting error:AMDP2_FE-6-EXCESSCOLL: Ethernet0/0 TDR=1, TRC=0
Router is connected to Switch, both router and switch config is below
can some body tell me how to fix up this issue as i am planning to change Duplex setting router from half duplex to full duplex
will this solve my problem
Router config:-
interface Ethernet0/0
description ### LAN ###
ip address 10.21.1.2 255.255.0.0
ip access-group 141 in
ip route-cache flow
half-duplex
standby ip 10.21.1.1
standby preempt
end
Switch config
interface GigabitEthernet0/1
description ***FREE***
no logging event link-status
no snmp trap link-status
no mdix auto
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree guard root
Erros
19 Replies 19
 %AMDP2_FE-6-EXCESSCOLL: Ethernet0/1 TDR=0, TRC=0
I am also facing same issue but my frame size is 256 only , but i am not hitting reaming frame sizes like (128,512,1024 Frame Sizes).
Do both sides of the link duplex match?
Hi Joseph,
Yes both sides are FULL DEPLEX only.
But it is hitting only 256 Frame size in C5921 IOS .
Can I know what is the use of these commands:
1. logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
2. logging console discriminator EXCESS
I don't see how your getting any collisions if both interfaces are (truly running) full duplex.
Since I see you're a Cisco Employee, you don't have access to TAC or any other internal resources to address this?
peter sithole
logging buffered 50000
