03-08-2011 10:23 AM - edited 03-04-2019 11:41 AM
Hi Folks
I Have 4 Mbps MPLS Link between Two Sites , I Received Complain from the Data Base Administrator ,there is a Delay and Latency appears on Logs when the database Replication occurs
Please Help to solve this issue
03-08-2011 11:15 AM
Soooo....
What have you done to being troubleshooting this?
1. Check utilization on both ends of the link
2. Check errors on the links.
3. What does the latency / delay look like if you do a db replication at the LAN vs across the WAN
4. Are you doing any prioritization?
5. Is there heavy traffic elsewhere in your LAN at either location that could be causing this
6. Any overloaded devices?
03-08-2011 12:23 PM
Thanks for your reply,can u expain the blow:
5.Is there heavy traffic elsewhere in your LAN at either location that could be causing this
How to verify the below:
03-08-2011 02:37 PM
Hi Ibrahim,
Normally you can use tools to grpah your traffic etc lik MRTG graphs, Cacti
However on the CLI you can issue the "sh interface
| i rate" depending on your device and interface. This shows you the 5 minute average intervals. You can change to lower interval say like 30 seconds as well
Again , sh interface
will show the crc, giants, runts depending on what interface your using 3. What does the latency / delay look like if you do a db replication at the LAN vs across the WAN
This will isolate if the issue is the DB server itself cause sometimes the DB server might be too busy to receive TCP connections etc.
This is related to Qos. meaning are you classifying any traffic as important and proritizing it.
Please rate if helpful
03-09-2011 10:05 AM
Hi Kishore
Can you Explain the Below:
regarding qos how to mark this sql traffic ,is it dscp AF31?also sql traffic its UDP or TCP?
what to tell the mpls provider in order to guarantees sql traffic as missin critical data
03-09-2011 11:10 PM
Hi Ibrahim,
This basically means to find out if the issue is with the DB server. If the DB server is busy then it will affect even the local site users as well. So this means that even the remote office users wil be affected.
depends on what you are using Sql uses both tcp and udp. you can set it to AF31 . that should be fine
http://en.wikipedia.org/wiki/List_of_TCP_and_UDP_port_numbers
you need to work with the ISP to mark your traffic as mission critical. you need to buy Qos from them though
HTH,
Kishore
03-12-2011 06:43 AM
Hi folks
03-13-2011 12:31 AM
Hi Ibrahim,
Also, please check the utilisation and memory as well on the devices using " sh proc cpu sorted" and "sh proc mem sorted"
Kishore
