Extended ACL Block IP
chrissnop
Block IPs using extended ACL
Block incoming traffic.
Is this correct?
apply to fa0:
int fa0
ip access-group block_ips in
block ips:
ip access-list extended block_ips
deny ip host 15.16.17.18 any
deny ip host 15.16.17.19 any
If extended ACL is used do I need to define outgoing as well, or no need?
If outgoing is needed, is the config below correct?
int fa1
ip access-group permit_internal out
ip access-group extended permit_internal
permit ip host 0.0.0.0 0.0.255.255 any
Thanks for any help.
hi,
you usually allow LAN/inside traffic to anywhere so you don't need an outgoing ACL applied on your fa1.
if you want to add entries/ACE on the IP ACL, just insert entry/ACE. issue first a show ip access-list block_ips.
 10 deny ip host 15.16.17.18 any
 20 deny ip host 15.16.17.19 any
 30 permit ip any any
conf t
 no 30
 30 permit <SOURCE IP> <WM> <DEST IP> <WM>
 40 permit ip any any
5 Replies 5
johnlloyd_13
Level 9
Level 9
hi,
you'll need to allow the rest of the network traffic after blocking specific IP subnets.
 permit ip any any
Thanks for the heads up.
Outgoing is not needed?
I hope you don't mind me asking again.
If I want to add to an existing extended acl "block_ips", how do i do it?
Thanks  again.
hi,
conf t
 no 30
Ah okay the system itself will do an automatic numbering. Thank you so much.
the sequencial number is cisco style and it increments by 10 , but u can choose 11,12 if you want.
Also, make sure that in an ACL, after you give your statements, by default cisco treats the next statement as an " EXPLICIT DENY ", so permit the entire N/W
