Fail over between 2 router
shashanksgr251
We have 2 Cisco router with two separate ISP. Also, two ASA firewall is centralised one and we are manually adding static routes in ASA.
But now need to enable auto failover.
What and all the possibilities plz...
Shashank.S
Richard Burts
Shashank.S
I am not clear what you mean when you tell us about two ASA. Are you telling us that they operate as a failover pair or that they operate as two independent firewalls?
I did a project for a customer where there were two routers each with a connection to an ISP. We ran a dynamic routing protocol between the two routers and the ASA firewall pair. Each router advertised its routes to the ASA and if one outside route failed then all traffic used the surviving outside route. I would think this approach could work for you.
Rick
Rick
