Failover in l2 switch
Bikas Giri
I have got a l2 link of 512 kbps from two different ISP. I want to aggegrate the bandwidth of this connection so that I can feel like having 1 mbps connection. I am not actually talking about load balancing, but bandwidth/link aggegration. Can we have the solution of failover with different vlan from different isp ? Can we be able to make the link as a single link.
Bikas
Vaibhava Varma
Level 4
Level 4
Hi Bikas
If we have L2 Links from ISP then the end site Routers/Switch terminate that Link and its in the control of the Site-Devices but not the ISP to aggregate them and yes they can be very well aggregated subject to the type of L2 Connectivity we have taken from ISP.
If its L2-Port Mode Ethernet Link from ISP then there is no issue in aggregation.
But if its L2-VLAN Mode Ethernet Link whereby we are sending tagged frame to ISPs in different VLANs then aggregation will not help us as either of the ISP will be dropping the other VLAN belonging to different ISP on their L2 Link. Had it been same VLANs for both ISP L2-Links we could have been able to aggregate them fine and make use of the bundled links in terms of aggregate Bandwidth.
Hope this answers your query.
Varma
Vaibhava Varma
Level 4
Level 4
Hi Bikas
Varma
The ISP can give both, the port based and vlan based. What should I do to aggegrate the links at my site, will the router or other managable switch help me in this regards.
Bikas
Hi Bikas
You can go for a port-based L2 circuit from the two ISPs ( using existing Switch) and do ether-channelling to bundle the two links.Still remember you will need to enable ether-channel load-balancing if we want to utilize both the L2 links optimally.
Please refer the below helpful documentation for same
Ether-Channel Config
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a00800ef797.shtml
Ether-Channel Load-Balancing
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
Hope this helps to answer your query
Varma
