Fair queue vs fifo
muca
Level 3
Level 3
I have routers and ap´s. All interfaces are configured with fifo.
Should I use fair queue instead? Is it a better choice? Even with the 350 Ap´s?
thanks
dgahm
Level 8
Level 8
FIFO is the default on ethernet interfaces because it usually works fine.
If you are experiencing congestion that is impacting interactive small packet traffic like telnet, then you might benefit from using fair queue.
