Fan issue
ahmad82pkn
Level 3
Level 3
Hi , in one month period my four routers are throwing FAN error, is it some kind of bug? :-s
Error 54721: Feb 24 14:04:33.447: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
any way to fix it other than replacing?
also any way to stop router sending its alert on syslog machine? its really a mess on my syslog, or any tune able syslog software? that can do filtering on special messages?
8 Replies 8
mvsheik123
Level 7
Level 7
This is what I found in Cisco website...
Error Message
%FAN-3-FAN_FAILED: Fan [dec] had a rotation error reported
Explanation The fan experienced a rotation error.
Recommended Action Replace the fan if it is not rotating.
Error Message
%FAN-3-FAN_OK: Fan [dec] had reported a previous rotation error, however
is now functioning
Explanation This is an informational message only. A fan that had reported a rotation error is now functional.
Recommended Action No action is required.
If the messages are popping up frequently, I definitely replace the FAN.
MS
Are those routers located in the same area? Do the routers have same version of code? Is the area too hot? Can you listen if the fans are rotating?
If you don't want any syslog messages from the routers you can use "no logging x.x.x.x" command.
Routers are on different locations, Cooling is normal,
Fans are rotating, i checked when i physically opened one of the router,
and i cant do no logging, because i have important data links on the circuit which i need to monitor.
Never used this command, but it's worth to see what it does
logging discriminator msg-body drops
i cant find above command in my cisco router:-s
What's the model of your router? What version of IOS are you running?
c3725-jk9s2-mz.123-15.bin
c3825-adventerprisek9-mz.124-7a.bin
i cant find this command on any of my routers.
We don't have any 3725s or 3825, but I see this command on 3845. The command is not available on 2811.
