Fan problem c3845 and c3725
leogemeostotino
I have two routers that have problems with the fans. It is a c3725 and c3845 (Fan 3).
I would like to know/confirm what are the products of these fans:
c3845: CISCO3845FANASSY= Cisco 3845 Fan Assembly and Bezel
c3725:  CK-3725-FAN (external product)
In c3845 can be exchanged only the Fan 3?
In c3725 the CK-3725-FAN work?
Sanjay Shaw
Leonardo,
Your two queries answer are below:
1.In C3845 you can swap the new fan assembly or you can also replace Fan 3 only.
2.Your CK-3725-FAN will work on c3725 router.
Your both the product code are correct.
Please rate this if u find useful.
BR// S S
What is the product code of the "Fan 3" c3845?
Hi Leonardo,
Product code/ Part No.: CISCO3845FANASSY
BR// SS
Please rate point if found useful
