07-12-2011 02:08 PM - edited 03-04-2019 12:57 PM
I am having some issues with a 861W router connected to a cable modem. Traffic is passing fine but my SNMP monitoring tool is showing continual changes to the ifLastChage mib. Debug of interface states gives the following:
Jul 12 21:03:36.450: [IDB Fa4 UURUYY] CSTATE_REQ: Entry, requested state: U
Jul 12 21:03:36.450: [IDB Fa4 UURUYY] CSTATE_REQ: starting ctimer (2000)
Jul 12 21:03:36.450: [IDB Fa4 UURUYY] CSTATE_REQ: state assign
Jul 12 21:03:36.450: [IDB Fa4 UURUYY] LSTATE_REQ: Entry
Jul 12 21:03:36.450: [IDB Fa4 UURUYY] LSTATE_REQ: Exit
Jul 12 21:03:36.450: [IDB Fa4 UURUYY] CSTATE_REQ: Exit
Jul 12 21:03:38.451: [IDB Fa4 UURUYY] CSTATE_TMR: Entry
Jul 12 21:03:38.451: [IDB Fa4 UURUYY] CSTATE_TMR: netidb=Fa4, linestate: Y
Jul 12 21:03:38.451: [IDB Fa4 UURUYY] CSTATE_TMR: starting lineproto timer
Jul 12 21:03:38.451: [IDB Fa4 UURUYY] CSTATE_TMR: Exit
Jul 12 21:03:39.451: [IDB Fa4 UURUYY] LSTATE_TMR: Entry
Jul 12 21:03:39.451: [IDB Fa4 UURUYY] LSTATE_TMR: not spoofing, current state: Y
Jul 12 21:03:39.451: [IDB Fa4 UURUYY] LSTATE_TMR: informing line state transitions
Jul 12 21:03:39.451: [IDB Fa4 UURUYY] TRANS_ADJ: Entry
Jul 12 21:03:39.451: [IDB Fa4 UURUYY] TRANS_ADJ: Exit
Jul 12 21:03:39.451: [IDB Fa4 UURUYY] ROUTE_ADJ: Entry
Jul 12 21:03:39.451: [IDB Fa4 UURUYY] ROUTE_ADJ: Exit
Jul 12 21:03:39.451: [IDB Fa4 UURUYY] LSTATE_TMR: Exit
Jul 12 21:03:46.451: [IDB Fa4 UURUYY] CSTATE_REQ: Entry, requested state: U
Jul 12 21:03:46.451: [IDB Fa4 UURUYY] CSTATE_REQ: starting ctimer (2000)
Jul 12 21:03:46.451: [IDB Fa4 UURUYY] CSTATE_REQ: state assign
Jul 12 21:03:46.451: [IDB Fa4 UURUYY] LSTATE_REQ: Entry
Jul 12 21:03:46.451: [IDB Fa4 UURUYY] LSTATE_REQ: Exit
Jul 12 21:03:46.451: [IDB Fa4 UURUYY] CSTATE_REQ: Exit
Jul 12 21:03:48.451: [IDB Fa4 UURUYY] CSTATE_TMR: Entry
Jul 12 21:03:48.451: [IDB Fa4 UURUYY] CSTATE_TMR: netidb=Fa4, linestate: Y
Jul 12 21:03:48.451: [IDB Fa4 UURUYY] CSTATE_TMR: starting lineproto timer
Jul 12 21:03:48.451: [IDB Fa4 UURUYY] CSTATE_TMR: Exit
Jul 12 21:03:49.451: [IDB Fa4 UURUYY] LSTATE_TMR: Entry
Jul 12 21:03:49.451: [IDB Fa4 UURUYY] LSTATE_TMR: not spoofing, current state: Y
Jul 12 21:03:49.451: [IDB Fa4 UURUYY] LSTATE_TMR: informing line state transitions
Jul 12 21:03:49.451: [IDB Fa4 UURUYY] TRANS_ADJ: Entry
Jul 12 21:03:49.451: [IDB Fa4 UURUYY] TRANS_ADJ: Exit
Jul 12 21:03:49.451: [IDB Fa4 UURUYY] ROUTE_ADJ: Entry
Jul 12 21:03:49.451: [IDB Fa4 UURUYY] ROUTE_ADJ: Exit
The router is running 15.0(1)M6 and, other than this issue all else is fine.Interface config is:
interface FastEthernet4
description Outside_Interface
bandwidth 50000
ip ddns update hostname *.*.*
ip ddns update DynDNS host members.dyndns.org
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex full
speed 100
no cdp enable
Any help would be very welcome!
07-12-2011 02:23 PM
Andy,
Just a guess, but would the situation change if you removed the commands duplex full and speed 100 from your Fa4 interface, and left the interface autonegotiate both the speed and duplex?
Best regards,
Peter
07-12-2011 02:38 PM
Change made and still no difference.
I also swapped the cable out just in case, still the same.
07-12-2011 03:07 PM
Can you post the output for the "sh int f4" please?
Have you tried changing the copper cable?
07-12-2011 03:19 PM
Here you go. The errors occured when I switched to hlf duplex to test a theory. Cable has been swapped with no change.
FastEthernet4 is up, line protocol is up
Hardware is PQII_PRO_UEC, address is 6400.f1ca.3c2c (bia 6400.f1ca.3c2c)
Description: Outside_Interface
Internet address is x.x.x.x
MTU 1500 bytes, BW 50000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 10/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 16
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2073000 bits/sec, 234 packets/sec
5 minute output rate 149000 bits/sec, 88 packets/sec
3020862 packets input, 3254412337 bytes
Received 2719 broadcasts, 60 runts, 0 giants, 0 throttles
60 input errors, 60 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
1506125 packets output, 282578369 bytes, 0 underruns
814 output errors, 318 collisions, 8 interface resets
0 unknown protocol drops
0 babbles, 0 late collision, 810 deferred
0 lost carrier, 0 no carrier
07-12-2011 03:39 PM
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1660 input errors, 60 CRC, 0 frame, 0 overrun, 0 ignored
The errors are odd. Also I forgot to ask you to clear the counters (clear counter f4) and how long has the router been up.
07-12-2011 04:00 PM
I clear counters after posting that last message, here is the current counter levels:
Last clearing of "show interface" counters 00:39:06
5 minute input rate 2077000 bits/sec, 237 packets/sec
5 minute output rate 153000 bits/sec, 103 packets/sec
527049 packets input, 585852454 bytes
Received 295 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
224818 packets output, 46422216 bytes, 0 underruns
Router has been up for around 6 hrs
07-12-2011 10:47 PM
Andy,
Can you perhaps swap the cables leading to ports Fa3 and Fa4 (along with swapping the port configurations if necessary) and see if the problem remains or moves to Fa3? At this point I would like to find out whether we are dealing with an issue with the port hardware, or whether the problem is indeed related to the cabling.
Best regards,
Peter
07-13-2011 12:09 AM
Sadly I can't - FastEth 0 to 3 are switchports - its an 861W .
I am going to try an IOS upgrade today and see if that helps but I am running out of ideas.
