Filesystem does not support verify operations.
Mavrick25
Level 4
Level 4
I was wondering if someone could help me out.
I need to perfrom a Cisco Router Upgrade, I downloaded the file correctly on my router and when I try to verify that the file was downloaded correctly,
I get the following error messasge:
%Filesystem does not support verify operations
%WARNING: Signature not found in file
Is there any particular reason as to why??
Please let me know..
Giuseppe Larosa
Hello Paolo,
I hope you are well
it is a question of file system type
not all file systems support the verify operation
you can check the file size and you can modify the boot order to have the new image attempted first leaving a second chance with current image
Hope to help
Giuseppe
Giuseppe Larosa
Hello Paolo,
I hope you are well
Hope to help
Giuseppe
Thanks again, I know I can count you..
Always a pleasure..
MAV
