Filtered ports on new 2900 router
Kevin Melton
Level 2
Level 2
Yesterday we installed a new Cisco 2911 router running IOS Version 15.0(1)M1.  After installation, I ran a scan against the router on its exposed side and found the following (scan conducted using nmap):
It is the filtered ports that I am concerned about.  We see ports 135, 139, 445, and 1720 open.  I am not sure why these even show up.
I would like to be able to run my scan, and not have the scanner pick up these ports at all.   Is there something I can disable on the router that will prevent these ports from showing up?
Kevin
tprendergast
Level 3
Level 3
There is actually nothing listening on those ports, the scanner just thinks they are filtered. It's a false-positive from nmap.
tprendergast
Level 3
Level 3
