Finding current path?
John Blakley
There's the "undocumented" do command in Cisco devices that allow you to run a exec command from global config like:
Router(config)# do sh run <enter>
This will show me the run command. Is there any equivalent to the Linux pwd command? Say that I'm in a class under a policy-map, but I don't remember which one. Is there a command that I can give to get the "present working directory?"
This would be SO cool if it exists, or maybe Cisco could put it in.
Thanks!
John
HTH, John *** Please rate all useful posts ***
Edison Ortiz
do show history command will provide the trail on how you got there.
__
Edison.
Thanks Edison! That's as close as I'm probably going to get. :-)
--John
ariesc_33
in unix, it doesnt show in the screen on which directory you are working on, that is why you need the "pwd" command. in cisco routers, you can actually see the path already
Router(config-policy-list)# match
