Firewall Config Packet Tracer- Help Required
ayesha1
I was wondering if anyone can help. I have a project due in the next few days. I have created two networks and I need to insert the firewall, I have watched loads of videos , but its not making sense. Is there anyone available that I could have a one to one with to help me figure out the config according to my network. I'm no expert learning as I'm going along, been working on it for over a week now and running out of time now. Any help would be appreciated.
Thank you
I have changed the access list on the firewalls to allow all traffic. I don't know what the requirements are and what you are supposed to block. DNS resolution from the AKCHQ clients now works...
20 Replies 20
post your zipped Packet Tracer project (.pkt) file...
Hi, it wont let me upload it, advising "The file type .pkt is not supported. Can I email it to you by any chance? I havent done any config on the firewall at all, because I dont understand it, but I have placed the firewalls where I would like them to go. I need to to site to site vpn connection but part of the requirements are that I use at least one firewall. Please let me know if I can email it you or send it to you another way?
you need to ZIP the .pkt file first...
Sorry you did say that before. I've attached it.
Thank you for your help.
I got the file...I'll have a look...
what are the project requirements, can you post the instructions ?
Is there anywhere I can send the instructions as a private message rather then on a public post?
sure, just send me a private message.
Thank you Ive sent the criteria to you.
there are a lot of ways to accomplish this. I used two different firewalls, the 5506-X, because they support EIGRP.
Attached the revised file with end to end connectivity.
Thanks I really appreciate your help witht this, is there any chance you could explain to me how you got it to work? I need to be able to understand how it was configured. Which version of packet tracer did you use, the file wont open because its not compatible. I've been using version 8.1.0.
you need to download and install the latest version 8.1.1.
Thanks, Ive done that. The webserver isnt communicating across both networks, did you use acls?
sorry for the delay, I am in the GMT +1 time zone. Here are the full configs:
