firewall setup
anitachoi3
I will install cisco 1811 (with firewall feature set) to be a firewall to block the ICQ/YM/MSN. one interface is connected to ISP, the next interface is connected to internal
1. how to block the "ICQ/YM/MSN" and permit other traffic? any sample config?
### router config
interface e0
ip address 210.x.x.1 255.255.255.252
ip nat out side
interface e1
ip nat inside
2. if I build the VPN to another remote branch, how to config it?
e.g. remote branch ip is 192.168.128.1/24
3. how can I setup the DMZ (e.g. 211.1.1.1/28 segment for DMZ)?
rdgs
ROBERTO TACCON
Level 4
Level 4
you can configure the IOS router with 2 mode of Firewall operation: with Classic FW or with Zone-Based FW.
!!! Try to configure the router with the new solution Zone-based FW: Additional parameters can be applied to specify connection volumes or actions such as URL filtering for HTTP traffic ... !!!
Check all the documents:
http://www.cisco.com/en/US/products/sw/secursw/ps1018/prod_white_papers_list.html
For the last IOS release configuration (Cisco IOS Software Release 12.4(9)T):
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a008060f6dd.html
