firmware version
Rajat.Kothari
Community Member
We have Cisco Switches in our organisation.
As a security perspective, i nedd to know the firware version of all my models.
Which is the best solution to get it???
Guru Mysoruu
Level 4
Level 4
HI,
Login to switch and Execute sh version command and pull the results.
Or if you have a centralized Core switch,login to switch and pull cdp neigbours details.
And you will be get it.
Gurudath K S
Ways to check:
Normal/Single Router/Switch:
Show version.
Router#show ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(28)>>>>>>>. this is the IOS version.
System image file is "flash:c2600-i-mz.122-28.bin">>>>>>> Exact image which is running on the box.
b)
R1#sh cdp ne de
Version :
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(28)>> this will give you the major ios id.
Stack:
Show ver
remote command show version>>>>>>>> this will read out the show version outputs for all the switches in the stack in one single command.
