Flexible Netflow and ingress vs. egress monitoring
Venison Mogambi
I've been playing around with Flexible Netlfow and I'm confused about the ingress vs. egress direction when configure flow monitors. I set up an output monitor like this:
flow monitor Monitor_Customer_Traffic
 record netflow ipv4 original-output
So the "output" at the end of that indicates that egress traffic should be captured, correct?
But then when I go to apply to traffic to an interface, I get both an input and output option:
R1(config-subif)#ip flow monitor Monitor_Customer_Traffic ?
  input      Apply Flow Monitor on input traffic
  multicast  Apply Flow Monitor on multicast traffic
  output     Apply Flow Monitor on output traffic
So what's the difference between specifying an output flow when configuring the monitor and specifying output direction when applying the flow monitor to the interface? And what happens if I specify output when I configure the monitor but then apply it to the interface inbound?
Any feedback is appreciated.
Mark Malone
I believe when you use that it just aggregates all the commands so it will include say all the below but you still need to state the direction under the ip interface to collect it but it will collect all the below with just that one command for egress
NetFlow IPv4 Original Output Predefined Record
The Flexible NetFlow "NetFlow IPv4 original output" predefined record is used to emulate the original NetFlow Egress NetFlow Accounting feature that was released in Cisco IOS Release 12.3(11)T. The key and nonkey fields and the counters for the Flexible NetFlow "NetFlow IPv4 original output" predefined record are shown in the table below.
Table 2 Key and Nonkey Fields Used by the Flexible NetFlow NetFlow IPv4 Original Output Predefined Record
Field
Key or Nonkey Field
Definition
IP ToS
Key
Value in the ToS field.
IP Protocol
Key
Value in the IP protocol field.
IP Source Address
Key
IP source address.
IP Destination Address
Key
IP destination address.
Transport Source Port
Key
Value of the transport layer source port field.
Transport Destination Port
Key
Value of the transport layer destination port field.
Interface Output
Key
Interface on which the traffic is transmitted.
Flow Sampler ID
Key
ID number of the flow sampler (if flow sampling is enabled).
IP Source AS
Nonkey
Source autonomous system number.
IP Destination AS
Nonkey
Destination autonomous system number.
IP Next Hop Address
Nonkey
IP address of the next hop.
IP Source Mask
Nonkey
Mask for the IP source address.
IP Destination Mask
Nonkey
Mask for the IP destination address.
TCP Flags
Nonkey
Value in the TCP flag field.
Interface Input
Nonkey
Interface on which the traffic is received.
Counter Bytes
Nonkey
Number of bytes seen in the flow.
Counter Packets
Nonkey
Number of packets seen in the flow.
Time Stamp System Uptime First
Nonkey
System uptime (time, in milliseconds, since this device was first booted) when the first packet was switched.
Time Stamp System Uptime Last
Nonkey
System uptime (time, in milliseconds, since this device was first booted) when the last packet was switched.
