Floating CPU load
Greg Maaaag
Level 3
Level 3
Good day!
Today We've got floating CPU load.
At first high cpu load was with ARP input. Then it switched to IP input, then IGMPSN and then from the begining.
show ip traffic
IP statistics:
  Rcvd:  1141302 total, 507413 local destination
         0 format errors, 0 checksum errors, 347937 bad hop count
         0 unknown protocol, 284873 not a gateway
         0 security failures, 0 bad options, 722529 with options
  Opts:  0 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 0 record route
         0 stream ID, 0 strict source route, 722529 alert, 0 cipso, 0 ump
         0 other
  Frags: 7 reassembled, 0 timeouts, 0 couldn't reassemble
         15 fragmented, 30 fragments, 0 couldn't fragment
  Bcast: 1044628 received, 5466 sent
  Mcast: 0 received, 0 sent
  Sent:  10368 generated, 767534 forwarded
  Drop:  97 encapsulation failed, 0 unresolved, 0 no adjacency
         0 no route, 0 unicast RPF, 0 forced drop
         0 options denied
  Drop:  0 packets with source IP address zero
  Drop:  0 packets with internal loop back IP address
         0 physical broadcast
  Reinj: 0 in input feature path, 0 in output feature path
ICMP statistics:
  Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 8 unreachable
        2677 echo, 1 echo reply, 0 mask requests, 0 mask replies, 0 quench
        0 parameter, 0 timestamp, 0 timestamp replies, 0 info request, 0 other
        0 irdp solicitations, 0 irdp advertisements
        0 time exceeded, 0 info replies
  Sent: 0 redirects, 372 unreachable, 23 echo, 2677 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp, 0 timestamp replies
        0 info reply, 1 time exceeded, 0 parameter problem
TCP statistics:
  Rcvd: 1839 total, 0 checksum errors, 743 no port
  Sent: 1753 total
PIMv2 statistics: Sent/Received
  Total: 0/0, 0 checksum errors, 0 format errors
  Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0,  Hellos: 0/0
  Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
  Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
  Queue drops: 0
  State-Refresh: 0/0
IGMP statistics: Sent/Received
  Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
  Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
  DVMRP: 0/0, PIM: 0/0
  Queue drops: 0
UDP statistics:
  Rcvd: 502604 total, 0 checksum errors, 495207 no port
  Sent: 5556 total, 0 forwarded broadcasts
OSPF statistics:
  Last clearing of OSPF traffic counters never
  Rcvd: 0 total, 0 checksum errors
        0 hello, 0 database desc, 0 link state req
        0 link state updates, 0 link state acks
  Sent: 0 total
ARP statistics:
  Rcvd: 1021500 requests, 477 replies, 10 reverse, 0 other
  Sent: 735 requests, 407852 replies (217281 proxy), 0 reverse
  Drop due to input queue full: 0
Config:
version 15.1
no service pad
service password-encryption
hostname Jardin
boot-start-marker
boot-end-marker
enable secret 5 *
enable password 7 *
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 10.0.1.1 10.0.1.99
ip dhcp excluded-address 10.0.0.1 10.0.0.99
ip dhcp pool 10.0.1.0/24
network 10.0.1.0 255.255.255.0
default-router 10.0.1.12
dns-server 192.168.10.100 192.168.240.100
ip cef
no ip domain lookup
ip domain name office
no ipv6 cef
license udi pid CISCO881W-GN-E-K9 sn FCZ1517C5V5
username cisco password 7 *
username wifiap privilege 15 secret 5 *
username admin privilege 15 secret 5 *
ip tcp synwait-time 5
crypto isakmp policy 10
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key 6 * address 89.223.6.92
crypto ipsec transform-set myset esp-aes esp-md5-hmac
crypto map vpn 180 ipsec-isakmp
set peer 89.223.6.92
set transform-set myset
match address 102
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
history PPS
interface FastEthernet4
ip address 89.104.102.230 255.255.255.240
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map vpn
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 192.168.201.197 255.255.255.0
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
ip address 10.0.1.12 255.255.255.0
ip flow ingress
ip nat inside
ip route-cache same-interface
interface Vlan2
ip address 10.0.0.12 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet4 overload
ip nat inside source static tcp 10.0.1.61 7000 89.104.102.230 7000 route-map internal extendable
ip route 0.0.0.0 0.0.0.0 89.104.102.225
ip route 192.168.240.0 255.255.255.0 89.223.6.92
logging esm config
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.11.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.16.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.17.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.18.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.19.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.240.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.250.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 100 deny   ip 10.0.1.0 0.0.0.255 10.0.1.0 0.0.0.255
access-list 100 permit ip 10.0.1.0 0.0.0.255 any
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.16.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.17.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.18.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.19.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.240.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 192.168.250.0 0.0.0.255
route-map vpn permit 10
match ip address 102
set interface FastEthernet4
line con 0
exec-timeout 5 5
privilege level 15
password 7 *
logging synchronous
login local
line aux 0
line 2
login local
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
privilege level 15
password 7 *
login local
transport input all
end
5 Replies 5
paolo bevilacqua
Already discussed in another thread:
https://supportforums.cisco.com/message/3748209#3748209
Please do not open duplicates.
It's another device with another problem. This device has floating cpu load not higher then 15%, other device has only IP input load at about 50% so i created 2 topics
If you mean that CPU load varies up to 15%, that is normal due to changing traffic volume, and  does not cause a problem.
it varies in process, at first 15% cpu load was by IP input, then 15% with ARP input, then 15% with IGMPSN and so on
for the last 30 min 15% by ARP input....isn't it high?
15% is not much really.
You can do debug arp to see what's going on with that.
