FM Core process
FabienneC
Dear all,
We suddenly noticed high CPU utilization on one of our 7600 routers. I output of show process CPU showed high utlization for the FM core process. I looked it up but did not find information on what this process does.
core-4#sh processes cpu sorted
CPU utilization for five seconds: 99%/11%; one minute: 88%; five minutes: 55%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
378       78448         984      79723 87.77% 16.14%  6.11%   0 FM core
231        1804        6526        276  0.16%  0.20%  0.16%   0 IP Input
225         208         984        211  0.08%  0.02%  0.01%   0 ADJ resolve proc
I appreciate any feedback on this.
Thank you,
Fabienne.
nkarpysh
This FM core process is responsible from translating the access-list/PBR
and move this into a format  that can be used to program this into the TCAM for traffic-processing.
I see that is not consistently High but spiking:
So it makes me think that you have quite long ACLs used for route-maps so when new updates are coming those ACLs are trigered and FM core start to work heavily. Am I right? If there is a chance to optimize ACL in the config or used Named ones if not already?
Nik
HTH,
Niko
nkarpysh
Nik
HTH,
Niko
Thank you Nik,
We had recently configured PBR on the router with a new ACL, we  shortened the ACL and removed uneeded entries. The CPU is now back to  normal.
Thanks again.
Good News!
If possible you can mark my answer as correct one for others to be able to use in future.
Nik
HTH,
Niko
Done:)
