forcing traffic over DMVPN tunnels with BGP without vrf's
I am having trouble setting up DMVPN in a virtual network in GNS3 for a proof of concept before putting in on a live network. I can get the static tunnels from the spokes to the hubs to come up but I cannot get traffic to pass though the tunnels. I can get dynamic tunnels between the spokes to form only if I ping the spoke tunnel IP directly. The routers in question are using BGP over a MLPS for routing but do not have any VRF’s configured. I was unable to find any info about using BGP without VRF’s. Is it possible or will I need to use VRF’s or a different routing protocol like OSPF or EIGRP to make the traffic use the DMVPN tunnels? Any help you can give will be greatly appreciated.
9 Replies 9
a.alekseev
Level 7
Level 7
What are you trying to do?
Trying to get all traffic coming from inside the network to the other other spokes to pass through the DMVPN tunnel.  If I ping one of the other spokes tunnel IP a dynamic tunnel gets setup but if I just send data to a spoke network it goes through outside the tunnel.
a.alekseev
Level 7
Level 7
You should run some IGP protocol over DMVPN (ospf, bgp, eigrp)
Everything I found for using BGP over DMVPN uses vrf's and that's not an option here. Was hoping not to have to use a different protocol.
post your configs and topology
I can only put in bits and pieces.  I am mimicking a live config and have to cut out a lot.  There are several spokes connected through a MPLS.
Tunnel Configs
Hub Config
interface Tunnel1
description mGRE - DMVPN Tunnel
bandwidth 1000
ip address 172.31.255.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication *******
ip nhrp map multicast dynamic
ip nhrp network-id 17231255
ip nhrp holdtime 450
ip tcp adjust-mss 1360
delay 1000
mpls ip
tunnel source ********
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile DMVPN-VPN
Spoke 3
interface Tunnel1
ip address 172.31.255.3 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast **********
ip nhrp map 172.31.255.1 **********
ip nhrp nhs 172.31.255.1
delay 1000
mpls ip
tunnel source GigabitEthernet0/1
tunnel key 100000
Spoke 4
interface Tunnel1
ip address 172.31.255.4 255.255.255.0
no ip redirects
ip mtu 1400
delay 1000
tunnel key 100000
ok, what is your BGP configuration?
Hub
router bgp 65001
bgp log-neighbor-changes
network 0.0.0.0
network 10.30.0.0 mask 255.255.255.0
neighbor <IP out to MPLS> remote-as 209
neighbor <IP out to MPLS> default-originate
neighbor <IP out to MPLS> soft-reconfiguration inbound
Spoke 4
router bgp 65001
network 10.20.0.0 mask 255.255.255.0
network 10.20.80.0 mask 255.255.255.0
network 10.251.0.20 mask 255.255.255.255
network 172.20.20.0 mask 255.255.255.0
Spoke 3
router bgp 65001
network 10.21.0.0 mask 255.255.255.0
MPLS
router bgp 209
redistribute connected
redistribute static
neighbor <ip to spoke 4> remote-as 65001
neighbor <ip to spoke 4> update-source GigabitEthernet0/3
neighbor <ip to spoke 3> remote-as 65001
neighbor <ip to spoke 3> update-source GigabitEthernet0/2
neighbor <ip to hub> remote-as 65001
neighbor <ip to hub> update-source GigabitEthernet0/0
neighbor <ip to spoke 1> remote-as 65001
neighbor <ip to spoke 1> update-source GigabitEthernet0/1
create vrf's on hub and spokes
for example
vrf definition mpls_vpn
rd 1:1
address-family ipv4
put mpls facing interfaces in vrf's
correct tunnels by adding "tunnel vrf mpls_core"
correct crypto keyring
move bgp sessions to "MPLS" router in address-family ipv4 vrf mpls_vpn
create bgp sessions in address-family ipv4
HUB must be route-reflector RR with source of tunnel and next-hop- unchanged
redistribute connected and static into bgp
