FR load balancing problem
Hello, I have 3 conections to my ISP. All of them are frame relay (E1), my problem is:
I configure as follow:
interface Ethernet4/1
ip address 200.109.243.129 255.255.255.248 secondary
ip address 200.44.154.185 255.255.255.248
no ip redirects
load-interval 30
interface Serial0/0
description Circuito 8151-0012318
bandwidth 1920
ip address 200.109.247.200 255.255.255.252
ip load-sharing per-packet
encapsulation frame-relay IETF
no ip mroute-cache
load-interval 30
serial restart-delay 0
fair-queue
frame-relay interface-dlci 350
frame-relay lmi-type ansi
interface Serial0/0
bandwidth 1920
ip address 200.44.111.174 255.255.255.252
no ip mroute-cache
load-interval 30
fair-queue
ip route 0.0.0.0 0.0.0.0 200.44.111.173
It works well but whe I add next ip route fron other valid network it becomes slow
example:
ip route 0.0.0.0 0.0.0.0 200.109.247.200 }
I put load-balancing per packect and per destination but it still the same.
Each conection is a E1.
Even when I make a Traceroute in the first case is very fast but when I add the second ip route and third is really slow.
How can I fix this problem? I want to use of all my links making load balancing
By now the only traffic is from my laptop nobody else is using this connections.
Leo
Edison Ortiz
IP Address on S0/0 is invalid. That's a subnet ID. Valid hosts within that subnet are from 200.109.247.201 to 200.109.247.202.
