FR loop
sp2727723
If carrier makes FR loop,can we see the loop on router by inputing show interface serial xxx?And how about the interface and line protocol?
mmolina10855
Typically you should see "UP/DOWN (Looped)" if the carrier has the loop pointing in the right direction.
Does FR has any loop detection tech?
scottmac
Level 10
Level 10
You can see the loop by doing a "Show Controllers"
In normal mode, you'd normally see a line that says"Loopback not set"
In loop mode, it indicates that a loop is up.
Loopback must be enabled on the interface or the carrier will not be able to put up the loop. The command is "loopback enable" .... but I don't remember if it goes on the "Service Module" or the serial interface.
In that case (loopback mode not enabled), you'll get a report back from the carrier "We could loop the smartjack, but not the CSU, you have a problem with either the extended demarc (the cable from the smartjack to the router/CSU) or your equipment."
Good Luck
Scott
