Cisco 2610XM T1 setup
chrisvchrisv
I’m having a problem setting up a 2610xm as a basic router. From the console of the router I can ping the Internet (yahoo.com, etc) but from the host (78.x.x.3) I can not ping past the router. I can ping the FastEthernet0/0 and the Serial0/0.1 interface ip addresses, but can not get past that. I want the host 78.x.x.3 to have full access to the Internet and have the Internet have full access to the computer on 78.x.x.3.
Here is my config, thanks in advanced:
hostname 2610XM
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxx
enable password password
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip name-server 78.x.x.6
no ftp-server write-enable
interface FastEthernet0/0
ip address 78.x.x.x.255.255.240
ip access-group 100 in
no ip mroute-cache
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
no fair-queue
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
ip address 78.x.x.x.255.255.252
ip access-group 101 in
frame-relay interface-dlci 737
ip classless
ip route 0.0.0.0 0.0.x.x.x.86.65
no ip http server
access-list 100 permit tcp any any established
access-list 100 permit ip host 78.x.x.3 any
access-list 101 deny ip 78.x.x.0 0.0.0.15 any
access-list 101 permit tcp any any established
access-list 101 permit ip any host 78.x.x.3
line con 0
exec-timeout 0 0
line aux 0
login
line vty 0 4
password xxx
login
end
mmandel
Remove the access list 100 on your FastE0/0
Only use one access list on the serial0/0.1
access-list 101 permit ip 78.79.223.0 0.0.0.15 any
access-list 101 permit ip any host 78.79.223.3
access-list 101 permit ip host 78.79.223.3 any
I got rid of the access list 100, and used the 101 on the serial0/0.1 but am still having a problem accessing the Internet with the host computer. Are these the correct network settings for the host computer?
IP Address = 78.79.223.3
Sub Mask = 255.255.255.240
Def Gateway = 78.79.223.1
DNS = 78.79.223.1 & 78.79.196.6
If these are the correct settings for the host computer, can you see anything else I'm missing in my router config?
hmmm? ya, that all looks fine. Try removing the access list 101 from the serial int. Those are all public addresses, so you don't need to do any NATing.
huzhg_8
you config :"interface FastEthernet0/0
ip address 78.69.223.1 255.255.255.240"
but you host ip :78.79.223.3????
what ??? they are not in a same subnet!!
