frame-relay cant ping from pont to point to multipoint
ChRiStEw1234
hi all,ive set up a frame relay lab using a fr switch for multi point  also have set up a point to point through the switch to 1 of the mp  routers(drawing of topology to be added),the pvcs work and i can ping  from first router to both multi points and from multi r1 to multi r2 and  can ping the point to point link 2 but cannot ping between p2p and  multi point
can ping from r1s0/0.102-103(191.168.123.1)191.168.123.2 s0.201 and 3(multi point) 301
and can ping from r1(191.168.12.1)s0/0.112 to r2 191.16812.2 211 s0/0.211
but cannot ping from 191.168.123.3 to 191.168.12.2
heres the show run from all 3 routers and fr switch
R1
version 12.3
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname tewys-comm-server
boot-start-marker
boot-end-marker
enable secret 5 $1$Shr4$9O6/xjfAwHjxpmjcxD0c..
username chris secret 5 $1$eys4$LG5zu.XkuVocDQCma1X070
username cisco password 7 13061B13181F
no aaa new-model
ip subnet-zero
ip domain list cisco.com
no ip domain lookup
ip host 3620-2 2002 172.21.1.1
ip host 2620-rj 2003 172.21.1.1
ip host 3640-1 2001 172.21.1.1
ip host SW1-1 2004 172.21.1.1
ip host SW3-3 2005 172.21.1.1
ip host 3640-rj 2003 172.21.1.1
ip host 2621-1 2001 172.21.1.1
ip host 2950-1 2004 172.21.1.1
ip host 2950-2 2005 172.21.1.1
ip host 2950-3 2006 172.21.1.1
ip host 3600-3 2014 172.21.1.1
ip host 3600-2 2013 172.21.1.1
ip host 5200-1 2010 172.21.1.1
ip host 2600-1 2008 172.21.1.1
ip host 2509-1 2007 172.21.1.1
ip host 4500-1 2015 172.21.1.1
ip host 3600-1 2012 172.21.1.1
ip host 2600-r2 2002 172.21.1.1
ip host 3640-r3 2003 172.21.1.1
ip host 2621-r1 2001 172.21.1.1
ip host 5200-2 2011 172.21.1.1
ip host 2950-sw3 2004 172.21.1.1
ip host 2950-sw2 2005 172.21.1.1
ip host 2600-2 2009 172.21.1.1
ip host 2950-sw1 2006 172.21.1.1
ip host pix-1 2016 172.21.1.1
interface Loopback0
ip address 172.21.1.1 255.0.0.0
interface Loopback1
no ip address
interface Ethernet0
ip address 171.123.1.1 255.255.255.0
no ip mroute-cache
interface Serial0
no ip address
no ip split-horizon
encapsulation frame-relay
no ip mroute-cache
no fair-queue
interface Serial0.102 multipoint
ip address 191.168.123.1 255.255.255.0
frame-relay map ip 191.168.123.2 102 broadcast
frame-relay map ip 191.168.123.3 103 broadcast
interface Serial0.112 point-to-point
ip address 191.168.12.1 255.255.255.0
frame-relay interface-dlci 112
interface Serial1
no ip address
shutdown
router eigrp 10
network 171.123.1.0 0.0.0.255
network 191.168.12.0 0.0.0.255
network 191.168.123.0 0.0.0.255
auto-summary
ip default-gateway 171.55.31.1
no ip http server
ip classless
alias exec c copy run start
line con 0
exec-timeout 0 0
logging synchronous
transport preferred telnet
line 1 16
session-timeout 20
exec-timeout 0 0
no exec
transport input telnet
line aux 0
logging synchronous
transport input all
speed 38400
flowcontrol hardware
line vty 0 4
exec-timeout 60 0
password 7 13061E01080344
logging synchronous
login
end
1)on the FR switch, no need for any routing protocol as well as FR mappings, this is just a switch.
   But it is not configured as a FR relay switch in the output config you posted ? where is this part of the config
2) on R1: on the multipoint subnet  you must have s0.103 pointing to R3 and not s0.102 which is already pointing to R2
      if you want to use a FR switch
3) split-horizon problem symptom is the spokes see the hub routes but not the other spokes routes so on the hub which should be R1 you have to disable split-horizon for the EIGRP process with the no ip split-horizon eigrp x interface command.
Regards.
Alain.
8 Replies 8
ChRiStEw1234
sorry its like this but couldnt paste all in 1 post for some reason#
R2
version 12.4
hostname BERLIN
boot-start-marker
boot-end-marker
enable secret 5 $1$M.5O$tU0pO7ImmP4A/X9Yj1K5y/
no aaa new-model
resource policy
ip cef
no ip domain lookup
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
no fair-queue
no dce-terminal-timing-enable
interface Serial0/0.201 multipoint
ip address 191.168.123.2 255.255.255.0
frame-relay map ip 191.168.123.1 201 broadcast
frame-relay map ip 191.168.123.3 201 broadcast
interface Serial0/0.211 point-to-point
ip address 191.168.12.2 255.255.255.0
frame-relay interface-dlci 211
router eigrp 10
auto-summary
ip http server
control-plane
banner login
C
!!!!!!!!!!GET OFF MY FUCKIN ROUTER OR U DIE!!!!!!!!!!
line con 0
exec-timeout 0 0
password 7 0822455D0A16
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 01100F175804
logging synchronous
login
end
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname STOCKHOLM
enable secret 5 $1$cK6v$GLqiVXDPgi2Kuz5hPbu7M.
ip subnet-zero
no ip domain-lookup
interface Ethernet0
ip address 194.111.0.1 255.255.255.0
interface Serial0
no ip address
interface Serial0.301 multipoint
ip address 191.168.123.3 255.255.255.0
frame-relay map ip 191.168.123.1 301 broadcast
frame-relay map ip 191.168.123.2 301 broadcast
interface Serial1
no ip address
shutdown
router eigrp 10
network 191.168.0.0
network 194.111.0.0
ip http server
ip classless
banner login
C
line con 0
exec-timeout 0 0
password 7 05080F1C2243
logging synchronous
login
line 1 16
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 030752180500
logging synchronous
login
end
raame-relay switch
version 11.2
hostname STOCKHOLM
ip subnet-zero
no ip domain-lookup
interface Ethernet0
interface Serial0
no ip address
interface Serial1
no ip address
shutdown
router eigrp 10
network 191.168.0.0
network 194.111.0.0
ip http server
ip classless
banner login
C
!!!!!!!!!!GET OFF MY  ROUTER OR U DIE!!!!!!!!!!
line con 0
exec-timeout 0 0
logging synchronous
login
line 1 16
line aux 0
line vty 0 4
exec-timeout 0 0
logging synchronous
login
end
any ideas thanks
thanks chris
you surely have a problem with EIGRP split-horizon( but I just took a quick look at the configs and diagram).
Can you post output of sh ip route eigrp on all routers as well as sh ip eigrp neigh
Regards.
Alain .
hi cadet thanks for your reply,ok nso ill tell u wot ive done first then post the outputs,after your reply i looked in each routing tables and the route was there but as a summarised route sh i checked sh ip protocols and on all 3 routers i had not done no auto-summarisation,so added the command to all 3 router but not thr fr switch(do i need to??do i even need to enable eigrp on fr switch ??as i have)now some rout tables sh the route and some dont heres outputs
tewys-comm-server#sh ip route eigrp
D    192.168.10.0/24 [90/2198016] via 171.123.1.2, 00:19:57, Ethernet0
     172.30.0.0/24 is subnetted, 9 subnets
D       172.30.2.0 [90/409600] via 171.123.1.2, 00:19:57, Ethernet0
D       172.30.3.0 [90/409600] via 171.123.1.2, 00:19:58, Ethernet0
D       172.30.0.0 [90/409600] via 171.123.1.2, 00:19:58, Ethernet0
D       172.30.1.0 [90/409600] via 171.123.1.2, 00:19:58, Ethernet0
D       172.30.6.0 [90/409600] via 171.123.1.2, 00:19:58, Ethernet0
D       172.30.7.0 [90/409600] via 171.123.1.2, 00:19:58, Ethernet0
D       172.30.4.0 [90/409600] via 171.123.1.2, 00:19:58, Ethernet0
D       172.30.5.0 [90/409600] via 171.123.1.2, 00:19:58, Ethernet0
D       172.30.8.0 [90/409600] via 171.123.1.2, 00:19:58, Ethernet0
D    192.168.20.0/24 [90/2198016] via 171.123.1.2, 00:19:58, Ethernet0
D    192.168.1.0/24 [90/2198016] via 171.123.1.2, 00:19:58, Ethernet0
D    194.111.0.0/24 [90/2195456] via 191.168.123.3, 00:09:38, Serial0.102
     192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
D       192.168.2.0/24 [90/2195456] via 171.123.1.2, 00:19:59, Ethernet0
D       192.168.2.1/32 [90/2195456] via 171.123.1.2, 00:19:59, Ethernet0
R1
tewys-comm-server#sh ip eigrp neighbor
IP-EIGRP neighbors for process 10
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
2   191.168.123.3           Se0.102          139 00:10:49 1464  5000  0  16
3   191.168.123.2           Se0.102          129 00:20:31  101   606  0  23
1   171.123.1.2             Et0               12 00:21:09   20   200  0  23
0   191.168.12.2            Se0.112           11 00:21:09   22   200  0  22
BERLIN#sh ip route eigrp
     171.123.0.0/24 is subnetted, 1 subnets
D       171.123.1.0 [90/2195456] via 191.168.123.1, 00:15:13, Serial0/0.201
                    [90/2195456] via 191.168.12.1, 00:15:13, Serial0/0.211
D    192.168.10.0/24 [90/2710016] via 191.168.123.1, 00:15:13, Serial0/0.201
                     [90/2710016] via 191.168.12.1, 00:15:13, Serial0/0.211
D       172.30.2.0 [90/2323456] via 191.168.123.1, 00:15:13, Serial0/0.201
                   [90/2323456] via 191.168.12.1, 00:15:13, Serial0/0.211
D       172.30.3.0 [90/2323456] via 191.168.123.1, 00:15:13, Serial0/0.201
D       172.30.0.0 [90/2323456] via 191.168.123.1, 00:15:13, Serial0/0.201
D       172.30.1.0 [90/2323456] via 191.168.123.1, 00:15:13, Serial0/0.201
D       172.30.6.0 [90/2323456] via 191.168.123.1, 00:15:14, Serial0/0.201
                   [90/2323456] via 191.168.12.1, 00:15:14, Serial0/0.211
D       172.30.7.0 [90/2323456] via 191.168.123.1, 00:15:14, Serial0/0.201
D       172.30.4.0 [90/2323456] via 191.168.123.1, 00:15:14, Serial0/0.201
D       172.30.5.0 [90/2323456] via 191.168.123.1, 00:15:14, Serial0/0.201
D       172.30.8.0 [90/2323456] via 191.168.123.1, 00:15:14, Serial0/0.201
D    192.168.20.0/24 [90/2710016] via 191.168.123.1, 00:15:31, Serial0/0.201
                     [90/2710016] via 191.168.12.1, 00:15:31, Serial0/0.211
D    192.168.1.0/24 [90/2710016] via 191.168.123.1, 00:15:32, Serial0/0.201
                    [90/2710016] via 191.168.12.1, 00:15:32, Serial0/0.211
D    194.111.0.0/24 [90/2707456] via 191.168.12.1, 00:06:09, Serial0/0.211
D       192.168.2.0/24 [90/2707456] via 191.168.123.1, 00:15:34, Serial0/0.201
                       [90/2707456] via 191.168.12.1, 00:15:34, Serial0/0.211
D       192.168.2.1/32 [90/2707456] via 191.168.123.1, 00:15:35, Serial0/0.201
                       [90/2707456] via 191.168.12.1, 00:15:35, Serial0/0.211
R2
BERLIN#sh ip eigrp neighbor
                                            (sec)         (ms)       Cnt Num
1   191.168.123.1           Se0/0.201        166 00:17:04  165   990  0  29
0   191.168.12.1            Se0/0.211         12 00:17:59   25   200  0  28
R3
STOCKHOLM#sh ip route eigrp
     191.168.0.0/24 is subnetted, 2 subnets
D       191.168.12.0 [90/2681856] via 191.168.123.1, 00:01:29, Serial0.301
D    192.168.10.0/24 [90/2710016] via 191.168.123.1, 00:01:29, Serial0.301
D    192.168.1.0/24 [90/2710016] via 191.168.123.1, 00:01:29, Serial0.301
D       192.168.2.0/24 [90/2707456] via 191.168.123.1, 00:01:29, Serial0.301
D       192.168.2.1/32 [90/2707456] via 191.168.123.1, 00:01:29, Serial0.301
D    192.168.20.0/24 [90/2710016] via 191.168.123.1, 00:01:29, Serial0.301
D       172.30.2.0 [90/2323456] via 191.168.123.1, 00:01:29, Serial0.301
D       172.30.3.0 [90/2323456] via 191.168.123.1, 00:01:29, Serial0.301
D       172.30.0.0 [90/2323456] via 191.168.123.1, 00:01:29, Serial0.301
D       172.30.1.0 [90/2323456] via 191.168.123.1, 00:01:29, Serial0.301
D       172.30.6.0 [90/2323456] via 191.168.123.1, 00:01:29, Serial0.301
D       172.30.7.0 [90/2323456] via 191.168.123.1, 00:01:29, Serial0.301
D       172.30.4.0 [90/2323456] via 191.168.123.1, 00:01:30, Serial0.301
D       172.30.5.0 [90/2323456] via 191.168.123.1, 00:01:30, Serial0.301
D       172.30.8.0 [90/2323456] via 191.168.123.1, 00:01:30, Serial0.301
D       171.123.1.0 [90/2195456] via 191.168.123.1, 00:01:30, Serial0.301
STOCKHOLM#sh ip eigrp neigh
                                        (sec)         (ms)       Cnt Num
1   191.168.123.1           Se0.301      125 00:03:39   76   456  0  29
0   194.111.0.2             Et0           14 00:04:00   28   200  0  9
also do i need to do clock rate on the frame-relay serial links????
thanks again for your help sorry it took so long for me to reply
thanks chris
Regards.
Alain.
hi alain thanks for your reply
1)not sure where confiq gone did do the frame-relay switching command and also did frame-relay routes will check this out and get back to u
2)will check this and get back to u
3)ah i only did no ip split horizon command will change the command
thanks for all your help
chris
hi alain when i looked on R1 the commands for split horizon was for the eigrp process  so must of missed a bit off while copying and the frame relay switch was the whole wrong sh run not sure why i posted stockholm twice lol so the fr switch has all the right config,it was no 2 as soon as i did what u said i could ping accross,thanks for your help
chris
