frame-relay map ip command
billtaylor73
The frame-relay map ip 192.168.1.1 110 broadcast command in the Cisco Press ICND book states that the DLCI and IP addresses are both at the remote end of the link. Other texts that I have refer to a remote IP address being mapped to the local DLCI. I am assuming that the latter is the case, can you please confirm? Thanks
Richard Burts
William
You are correct. The remote IP is mapped to the local DLCI.
Rick
Rick
