04-03-2013 01:23 AM - edited 03-04-2019 07:28 PM
Anyone can help me?
Encountered problem in configuring frame relay multipoint.
Status 0x0.
All the router not connected. When do ping result is host unreachable.
Configuration in Router HQ >>
1. int Fa0/0: 192.168.0.78/29
2. int Serial0/0
encapsulation frame-relay
no shut
3. int Serial0/0.1 multipoint
ip add 10.0.0.167 255.255.255.252
bandwidth 64000
frame-relay map ip 10.0.0.5 102 broadcast
frame relay map ip 10.0.0.9 103 broadcast
frame relay map ip 10.0.0.13 104 broadcast
no ip split-horizon
4. router rip
version 2
network 10.0.0.0
no auto-summary
Thanks!
04-03-2013 01:27 AM
Correction on Router HQ.
ip add 10.0.0.17 255.255.255.252
04-03-2013 01:47 AM
Hello
Your hub router ip range isnt large enough accomodate the spokes also if you use point-to-point on the spokes
no need to use the broadcast keyword
Hub router
interface Serial0/0
no ip address
no shut
ip add 10.0.0.167 255.255.255.0
bandwidth 64000
Spoke router5
interface Serial0/0
no ip address
no shut
int Serial0/0.1 point-to-point
frame-relay interface-dlci 201
Spoke router9
interface Serial0/0
no ip address
no shut
frame-relay interface-dlci 301
Spoke router13
interface Serial0/0
no ip address
no shut
ip add 10.0.0.13 255.255.255.0
frame-relay interface-dlci 401
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
04-03-2013 11:10 AM
Hello Khairul,
I understand that you are trying to configure a Frame-Relay Multipoint Topology with hosts on every spoke site be able to communicate with the Hub as well other spokes.
Basically, the IP address assignment for the WAN interfaces was wrong. Since, this is a multi-point topology, all the sites (Spokes and Hub) will be part of the same subnet.
For your understanding, I have re-created the same topology in GNS and below, you can find the topology with complete configurations.
Router Configs:
R3:
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface Serial1/0
ip address 10.0.1.1 255.255.255.0
serial restart-delay 0
frame-relay map ip 10.0.1.2 305 broadcast
frame-relay map ip 10.0.1.3 306 broadcast
frame-relay map ip 10.0.1.4 307 broadcast
router rip
network 1.0.0.0
network 10.0.0.0
no auto-summary
Frame-Relay Switch (ISP):
interface Serial1/0
no ip address
frame-relay intf-type dce
frame-relay route 305 interface Serial1/1 503
frame-relay route 306 interface Serial1/2 603
frame-relay route 307 interface Serial1/3 703
interface Serial1/1
no ip address
frame-relay route 503 interface Serial1/0 305
interface Serial1/2
no ip address
frame-relay route 603 interface Serial1/0 306
interface Serial1/3
no ip address
frame-relay route 703 interface Serial1/0 307
R5:
interface Loopback1
ip address 2.2.2.2 255.255.255.255
interface Serial1/0
ip address 10.0.1.2 255.255.255.0
frame-relay map ip 10.0.1.1 503 broadcast
frame-relay map ip 10.0.1.3 503 broadcast
frame-relay map ip 10.0.1.4 503 broadcast
router rip
network 2.0.0.0
network 10.0.0.0
no auto-summary
R6:
interface Loopback1
ip address 3.3.3.3 255.255.255.255
interface Serial1/0
ip address 10.0.1.3 255.255.255.0
frame-relay map ip 10.0.1.1 603 broadcast
frame-relay map ip 10.0.1.2 603 broadcast
frame-relay map ip 10.0.1.4 603 broadcast
router rip
network 3.0.0.0
network 10.0.0.0
no auto-summary
R7:
interface Loopback1
ip address 4.4.4.4 255.255.255.255
interface Serial1/0
ip address 10.0.1.4 255.255.255.0
frame-relay map ip 10.0.1.1 703 broadcast
frame-relay map ip 10.0.1.2 703 broadcast
frame-relay map ip 10.0.1.3 703 broadcast
router rip
network 4.0.0.0
network 10.0.0.0
no auto-summary
Hope your queries were answered
04-03-2013 11:46 AM
Hello Mithun
I have noticed in your config. Your mapping for spoke to spoke routers has broadcast keyword enabled,this should not be the case as it can cause unnecessary redundant routing traffic towards the hub router.
Res
paul
