Frame Relay - RV016
mauricioagra
Dears, I would like to know if I can configure the router linksy - Cisco to receive a Frame Relay link?
The protocol is sent pel PPP provider as part of a configuration below, which I received from the provider.
Protocol MLPPP / Routing / Static Routing Balancing NO / Address Block (LAN) 192.168.4.0 / Address Mask 255.255.255.0 / Topology Full MeshedQoS NO.
Giuseppe Larosa
Hello Mauricio,
after reading the service provider specifications I would say you should configure your device with encapsulation PPP or multilink PPP rather then frame relay.
It is possible to run PPP over Frame Relay but I don't know if this is your case.
Hope to help
Giuseppe
