frame-relay switch config
saidfarah
I am trying to convert a 2612 router to a frame-relay switch. What is the correct config? The below does not work.
Thanks.
Said
Router(config)#hostname FRswitching
FRswitching(config)#frame-relay switching
FRswitching(config)#int s1/0
FRswitching(config-if)#encap
FRswitching(config-if)#encapsulation frame-relay
FRswitching(config-if)#frame-
FRswitching(config-if)#frame-relay intf-type dce
FRswitching(config-if)#exit
FRswitching(config-if)#frame-relay route 18 int s1/1 16
FRswitching(config-if)#int s1/1
FRswitching(config-if)#frame-relay route 16 int s1/0 18
% Invalid input detected at '^' marker.
mheusinger
Level 10
Level 10
the following config is part of a production system (3640) and works:
interface Serial0/0
no ip address
clockrate 128000
frame-relay route 100 interface Serial0/1 100
interface Serial0/1
no ip address
clockrate 128000
frame-relay route 100 interface Serial0/0 100
What is your IOS version?
Hope this helps
Martin
Martin,
Thanks much. The config worked.
The IOS version on the router is Version 12.3(9).
Happy New year.
Said
scottmac
Level 10
Level 10
You need to set a clock rate on each interface after you declare it as a DCE.
Also make sure your cables are connected properly. Even with back-to-back cables, there is a "DCE" end and a "DTE" end. It should be marked on the cable near the connector.
If you do a "sh controller ," somewhere in the first few lines it will say which interface type the cable has configured the interface for.
Good Luck
Scott
Just a side note to the previous poster. The Layer1 DCE side has nothing to do with the Frame Relay DCE side.
We have choosen to have them both at the FR switch side, but you may also have them at different ends.
So "clock rate " is needed on the Layer1 (interface) DCE, but not needed on the Fame Relay DCE (frame-relay intf-type dce) side.
Hope this helps
Martin
