frame relay
cisco steps
since I reconfiguring frame realy switch ..
R1 can ping r2 and r3
R2 can ping r1
r3 can ping r1
r2 can not ping r3
r3 can not ping r2
frame-switch#sho frame-relay route
Input Intf Input Dlci Output Intf Output Dlci Status
Serial1/1 122 Serial1/2 221 active
Serial1/1 123 Serial1/3 321 active
Serial1/2 221 Serial1/1 122 active
Serial1/3 321 Serial1/1 123 active
interface Serial1/1
no ip address
encapsulation frame-relay
logging event subif-link-status
logging event dlci-status-change
clock rate 56000
no frame-relay inverse-arp
frame-relay intf-type dce
frame-relay route 122 interface Serial1/2 221
frame-relay route 123 interface Serial1/3 321
interface Serial1/2
no ip address
clock rate 56000
frame-relay route 221 interface Serial1/1 122
interface Serial1/3
no ip address
clock rate 56000
frame-relay route 321 interface Serial1/1 123
6 Replies 6
Reza Sharifi
Is r1 the hub and r2 and r3 are the spokes? If yes, are you running any dynamic routing protocols? If no, you need a static route from r2 poining to r1 and also static route from r3 pointing to r1.
Reza
Reza,
That is correct R1 is Hub r2 and r3 are the spokes.. no dynamic routing protocols ..
R2(config)#ip route 172.12.123.2 255.255.255.0 172.12.123.1
%Inconsistent address and mask
R3(config)#ip route 172.12.123.3 255.255.255.0 172.12.123.1
I tried that and I get and error
Thanks Resa
You need to point to the network no to the hose like:
ip route 172.12.123.0 255.255.255.0 172.12.123.1
I attached an example for your routers
Reza
correction
You need to point to the network not to the host
still not working RESA,
here is my topology, i went to r2 and added
and on r3
am I doing something wrong . is my frame relay config correct...
Are you using frame-relay inverse-arp betwen hub and spoke?.
If you use frame relay inverse-arp, try static host entry as below,
R2:
ip route 172.12.123.3 255.255.255.255 172.12.123.1
R3:
ip route 172.12.123.2 255.255.255.255 172.12.123.1
If you have static mapping, configure mapping for spoke pointing to your hub DLCI as below,
R2:
interface
frame-relay map ip 172.12.123.1 broadcast
frame-relay map ip 172.12.123.3
R3:
frame-relay map ip 172.12.123.2
If it doesnt work, Please post the config @ hub and spoke routers as well.
HTH,
Nagendra
