Frequent disconnectes to Cisco 2924 Management IP
f501664236
We have having frequent disconnection issues with Cisco 2924 Management IP...
If any one have information if this is a BUG!!
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5.2)XU, MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 17-Jul-00 17:35 by ayounes
Image text-base: 0x00003000, data-base: 0x00301F3C
ROM: Bootstrap program is C2900XL boot loader
DIGsgMUSclewm21 uptime is 29 weeks, 1 day, 8 hours, 40 minutes
System restarted at 22:10:26 UTC Sat Oct 4 2008
System image file is "flash:c2900XL-c3h2s-mz-120.5.2-XU.bin"
cisco WS-C2924C-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K bytes of memory.
Processor board ID , with hardware revision 0x01
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address:
Motherboard assembly number: 73-3381-08
Power supply part number: 34-0834-01
Motherboard serial number:
Power supply serial number:
Model revision number: A0
Motherboard revision number: C0
Model number: WS-C2924C-XL-EN
System serial number:
Configuration register is 0xF
srinivas_816
can you provide an brief connectivity between the Switch and all the work station.
Their my multiple reasons for the managment vlan disconnection.
it also plz attach the show logg
