FRTS for DECnet
Rojer-bkk
I got a problem with an application when it transferred data to remote site.
I found the speed of data transferring was limited under 64 Kbps, even though the communication line had bandwidth 256 kbps.
This application run on VMS and used decnet protocol.
I attached the QoS configure of head office and branch office
Thanks and appreciate for help!!
5 Replies 5
Rojer-bkk
have any idea?
Are you seeing any Packet drops in the qos policy applied on the interface
while transferring the file .
Syed
Syed,
Queueing
        Strict Priority
        Output Queue: Conversation 40
        Bandwidth 128 (kbps) Burst 3200 (Bytes)
        (pkts matched/bytes matched) 430624/145055584
        (total drops/bytes drops) 82760/42422233
As you mentioned the cause would be packet drops so how can i solve the packet dropped issue in queue?
Please be so kind to include full outputs of the following commands:
  • show policy-map
  • show class-map
  • show access-lists ! Interested in the ACL used in class-map
Best regards,
Peter
Hi Peter,
Thanks for response.
I found large amount of packets dropped. I'm not sure about configuration which could be incorrect or not praticable.
Kindly see output in attach files.
Thanks!!
