FTP through VPN 3030
lavanya_cisco
hello all
I have a FTP server on the outside of a VPN 3030 and a host on the private LAN. I'm doing simple static routing on the VPN 3030 to reach the ftp server.
FTP client - VPN 3030 - router ----> FTP server
From the router ethernet segment am able to FTP to the server.
From behind the VPN 3030, am able to ping the FTP server, but not able to FTP it. Will the VPN 3030 block application traffic forwarding ?? There are absolutely no port blocking anywhere else in the network..
Any suggestions please ??
6 Replies 6
how is your VPN 3030 connected to the router ? Can you post the configuration of your router ?
GP
Hello george,
VPn 3030 public and the router's FE int are put on a VLAN on a switch.. ie logically connected back to back.. again to be clear, am able to ping the ftp server from the client, but not able to do ftp or telnet on port 21.. similar thing happened when i tried to traverse through VPN 3030 for telnet/ssh earlier , before 6 months.. does the vpn 3030 block outbound application traffic, for security reasons ?? bypassing the vpn 3030 is the only solution for this ???
Router config is plain and simple:
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.50.1.1 255.255.255.0
no cdp enable
pls confirm...
the default VPN Concentrator traffic management rule is to allow any in/any out. I assume you have already checked if the default rule is still in place ? Can you do a ´telnet x.x.x.x 21´ (where x.x.x.x is the IP address of the FTP server) from the FTP client ? This just to verify that something is actually being blocked (if you get an ´open´ that would mean that FTP is going through, but that there is some other problem with e.g. the FTP server)...
GP
Hello GP,
I cannot do a telnet on port 21.. I had checked this already.. am sure VPN is blocking something.. anything else to be checked ??
can you try and reset the concentrator to factory defaults by deleting the "config" file (from the File Management screen) and rebooting the device ?
GP
hello GP,
this is a production box.. cant do this.. noway can i delete the file or reboot.
