Fully specified static route error
keesepema
In PacketTracer I'm trying to configure a fully specified static route. All interfaces on the routers are Ethernet and are interconnected with straight cables.
The router model is 4331.
When entering the route in the router CLI
ip route 10.10.10.0 255.255.255.0 g0/0/2 10.1.1.6
The command returns:
% Invalid input detected at '^' marker
In CCNA2 CH 15 static routing, the above command is accepted.
My question is, what is the correct way to define a static route?
sure then it is PKT limitation, your config is OK.
5 Replies 5
must be
  10.1.1.6 g0/0/2 <<- try this, first specifiy next-hop then egress interface
Thanks, however unfortunately the same error message is displayed. When I enter
ip route 10.10.10.0 255.255.255.0 10.1.1.6 g0/0/2
it still returns
marker appear under which word/ip ? can you share screen shot ?
I have attached a screeshot of the router cli.
