%FW-4-TCP_OoO_SEG: Dropping TCP Segment ERRORS
I have a SB6183 Cable modem connected to a Cisco 2851 Router...then to a Gigiabit switch.
The Cable Modem Power Levels:
Upstream Power Level is between 44.3 dBmV and 45.3 dBmV
Downstream Power level is between 4.3 dBmV and 4.8 dBmV
SNR is pretty much at 40.3
The Cisco 2851 is running c2800nm-adventerprisek9-mz.151-4.M12a.bin
The router has the 64gb Flash and 1tb System memory
I keep getting %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:3359405808 1500 bytes is out-of-order; expected seq:3359363468. Reason: TCP reassembly queue overflow - session 192.168.0.44:55755 to 67.26.217.254:80 (sometimes different IP address and Port) This is connected to my kid's XBOX ONE (192.168.0.44)
I have tried the following:
parameter-map type ooo global
tcp reassembly timeout 45
tcp reassembly queue length 1024
tcp reassembly memory limit 4096
But I still get the error in my syslog?
Does anyone have a suggestion?
0 Replies 0
