fw feature in ios routers
ohassairi
Level 5
Level 5
we use one cisco2811 router between two LANs as a firewall (while it contains fw feature)
(C2800NM-ADVSECURITYK9-M), Version 12.4(3g)
in classic firewalls (PIX) we can configure groups : set of computers, then in one rule we can make this group as source or destination.
but using fw feature in this router, i think it is impossible to do this. i must create one rule of each computer.
is there a way to use one group as a source or destination ?
any help?
thanks
Collin Clark
AFAIK you can not create groups like in the PIX/ASA, however if you look at the zoned-based firewall feature, you can do some grouping.
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00808bc994.shtml
Hope that helps.
