Getting internet to work from switch
jpanzica747
Visitor
I am new to working with Cisco stuff and asking questions on here, so I hope I am asking this in proper form.
I have a Linksys home router, connected to a Cisco 3825 router, connected to a Cisco 3560 switch.
The router is working well and able to ping the internet with no problem.
The switch is connected via port G0/1 on the router and f0/1 on the switch.
I cannot connect to the switch in any way from the Cisco 3825 router, however I do have VOIP working with the internet conncetion on G0/0 and phones connected to any port on the switch.
What I would like to do is connect to the switch from the router and also be able to access the internet from the switch.  I am sure I am routing something wrong but not sure how to figure out what.  Any help is super appreciated.
2 Accepted Solutions
the IP address of the Vlan 1 interface needs to be in the same subnet as the corresponding interface on the router (interface GigabitEthernet0/1 with IP address 10.10.30.1 255.255.255.0 in your case).
Change the IP address of Vlan 1 on the switch to:
interface Vlan1
ip address 10.10.30.248 255.255.255.0
and the default gateway to:
ip default-gateway 10.10.30.1
make the changes marked in bold. When you are done, post the full configurations of the switch and the router so we can double check everything:
Switch
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
switchport voice vlan 20
spanning-tree portfast
switchport trunk allowed vlan 1,10,20,55,77
switchport mode trunk
interface Vlan1
--> no interface Vlan10
ip address 10.10.10.248 255.255.255.0
ip classless
-> no ip route 0.0.0.0 0.0.0.0 10.10.1.100
ip http server
ip http secure-server
Router
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
ip address 10.10.30.1 255.255.255.0
ip nat inside
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.10
encapsulation dot1q 10
ip nat inside
duplex auto
speed auto
media-type rj45
ip nat inside source list 1 interface GigabitEthernet0/0 overload
--> no ip route 0.0.0.0 0.0.0.0 10.10.1.1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
--> no access-list 1 permit any
access-list 1 permit 10.10.0.0 0.0.255.255
16 Replies 16
balaji.bandi
Just think this scenario
Router---Linksys--Internet working.
here source IP of the router is outside interface, that is part of Linksys Router IP which is doing NAT, so this works
When you introuduce another network segment, in your case Switch like below
userPC--Switch---(inside)Router(outside)--Linksys--Internet.
Since Switch connected users not natted or router to uplink router that is Linksys not aware what is to be done.
1. best approach is Do Nat on Router for the Local LAN IP address with external outside IP. so Lan users can get Internet.
if you still have issue please post your Router / Switch config to fine tune to work.
BB
Georg Pauwen
--> however I do have VOIP working with the internet conncetion on G0/0 and phones connected to any port on the switch.
So you have an Internet connection from the phones connected to the switch ? In order to get to the switch from the router, the switch needs an IP address and a default gateway pointing to the router.
Post the full running configurations of both the router and the switch...
Yes, Internet is working on phones I think.  Unless it is bypassing internet and just working on the FXO port, which now that I think about it, this is probably what it is doing.
Here is a general topology of my setup:
Cable Modem <---> Linksys router <----> Cisco Router <---> Cisco Switch <---> Cisco Phones
- Linksys is using a 192.168.1.0/24 network
- Cisco Router has nat setup, and is able to do pings on the internet and seems to connect well with the Linksys router.
- I believe the switch has 10.10.10.10.0 network and is assigning the phones IPs from that network range.  I am not sure how the 10.10.20.0/24 and 10.10.30.0/24 networks are setup working as I am new and still learning what VLAN and NAT are configured and do exactly.  I understand the basic theory of it.
Computers are hooked up to the Linksys Router directly, but I would like to hookup devices to switch when it is working.
My configs are attached.
On Router change the config as below to work :
no ip address
no shutdown
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip nat inside
description ROUTER INTERFACE FOR DATA VLAN$FW_INSIDE$
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.20
description ROUTER INTERFACE FOR CME VOICE VLAN$FW_INSIDE$
encapsulation dot1Q 20
ip address 10.10.20.1 255.255.255.0
ip nat inside
I will also change ACCESS List as below for NAT
access-list 10 permit 10.10.10.0 0.0.0.255
access-list 10 permit 10.10.20.0 0.0.0.255
access-list 10 permit 10.10.30.0 0.0.0.255
no ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 10 interface GigabitEthernet0/0 overload
Then connect to PC to one of port and test and let us know.
Note : on the switch add VLAN 30 to trunk allowed list.
BB
make the changes marked in bold to your router configuration:
Current configuration : 8352 bytes
version 15.1
hostname r1
boot-start-marker
boot-end-marker
enable secret 8 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
aaa new-model
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
no network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.10.20.1 10.10.20.12
ip dhcp excluded-address 10.10.10.1 10.10.10.12
ip dhcp pool DATA_SCOPE
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool VOICE_SCOPE
import all
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
option 150 ip 10.10.20.1
ip domain name r1.xxx.com
no ipv6 cef
voice-card 0
crypto pki trustpoint TP-self-signed-XXXXXXXXXX
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-XXXXXXXXXX
revocation-check none
rsakeypair TP-self-signed-XXXXXXXXXX
crypto pki certificate chain TP-self-signed-XXXXXXXXXX
certificate self-signed 01
XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
quit
license udi pid CISCO3825 sn XXXXXXXX
username acetech privilege 15 secret 8 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
redundancy
controller T1 0/0/0
controller T1 0/0/1
ip address dhcp
ip nat outside
duplex auto
speed auto
media-type rj45
ip nat inside
duplex auto
speed auto
media-type rj45
ip nat inside
ip nat inside
interface Async0/1/0
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication aaa
ip http path flash:/gui
line con 0
line aux 0
line 0/1/0
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
exec-timeout 60 0
transport input ssh
line vty 5 15
exec-timeout 60 0
transport input ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server pool.ntp.org
end
I made the changes that you suggested to the router but it seems the switch is still unreachable from the router and the switch is not able to get access to the Internet.
If I ping google.com from the switch, it is using the domain server as 255.255.255.255.  I am not sure that is right and the ping is failing.
If I ping google.com from the router it is successful.
What is the proper way to connect to the switch from the router?  I assume it is something like ssh 10.10.30.1, correct?
Another thing that may be of interest is if I try to SSH to 10.10.10.1 or 10.10.20.1 from the router, it does a loopback and gives me a login to the router but not the switch.  I am not really sure what the IP of the switch is or how to access it.  Is it possible that it is now setup correctly and I am just not accessing the switch in the right manner?
Hello
Sw
conf t
int vlan 1
no ip address
int vlan 10
no ip route 0.0.0.0 0.0.0.0 192.168.1.128
no ip default-gateway 192.168.1.1
no ip routing
ip default-gateway 10.10.10.1
line vty 0 15
login local
privilege level 15
Kind Regards
Paul
interface Vlan1
You sir are awesome, thank you for the help.  I can now SSH from the router to the switch, by SSH'ing to the router from computer, then to switch via an SSH 10.10.30.248 command.  This makes working on the equipment so much easier without having to use a console cable.  I am able to ping 10.10.30.248 from my computer but not able to SSH to it directly.  It would be nice if I could just SSH directly to the switch from computer, do you have any recommendations on how to do this?
I hooked up laptop to a port on the switch and it is getting an IP and Internet is working on the laptop.  So that is a big progress.
I still am not able to do pings from IOS on the switch.  If I ping google.com it is trying to do so through 255.255.255.255.  Not sure if that is correct way it should be doing it or how to fix this or if it even needs to be fixed.
I also am not able to reach hosts on the switch from hosts on the linksys router.  For example, I have the laptop working on a port hooked up to the switch with IP of 10.10.10.14 and computer on linksys router with IP of 192.168.1.2 and a traceroute from the 192.168.1.2 shows it reaching the cisco router at 192.168.1.128, but times out from there.
I might have missed that, but where in your topology is the Linksys router ? How is it connectec (to the switch I assume) ?
For the SSH access, have you generated the RSA key ?
S1(config)# crypto key generate rsa 1024
And for the domain name pinging, try and configure:
S1(config)#ip name-server 8.8.8.8
S1(config)#ip domain lookup
Can you post again full modified config to verify.
BB
Hello
@jpanzica747 wrote:
I cannot connect to the switch in any way from the Cisco 3825 router, however I do have VOIP working with the internet conncetion on G0/0 and phones connected to any port on thr Switch
How doe this work then?
why can’t you physically connect the switch to the router
Kind Regards
Paul
Hey guys, I redid the network setup some thinking it would help to get everything working and it took me a while to get back to the point I was before.  I re-read your posts and it seems you guys are suggesting that I have my router hooked up to the switch.  I actually have the following topology:
Cable Modem <=> Linksys Router <=> Cisco Router <=> Cisco Switch
I have most of my hosts connected to the Linksys router.  When I get more familiar with Cisco equipment may migrate hosts over to the Cisco router.  I am able to ping the internet from the switch IOS interface.  I beleive that is because NAT is working.  I am however not able to communicate to hosts from the Linksys router to the Cisco router, or vice versa.  The traceroute from a host on the linksys router reaches the cisco router and is dropped from there.  The traceroute from the cisco switch, to a host on the linksys router, seems to not even make it to the next hop, which is the cisco router.  Sorry if that is long winded, I am just trying to explain all the details of what is going on.  I think it is some kind of routing issue, I am just not sure what though.
Here is some of the relevant config on my switch:
interface Vlan1
interface Vlan10
ip default-gateway 10.10.30.248
ip classless
ip http server
And relevant config on the router:
ip address dhcp
ip nat outside
duplex auto
speed auto
media-type rj45
ip nat inside
duplex auto
speed auto
media-type rj45
!ip nat inside source list 1 interface GigabitEthernet0/0 overload
The IP of the Linksys router is 10.10.1.1/24.
Any help to get this working so hosts between devices can talk to each other is appreciated.  I imagine I am missing a static route somewhere.  I am also learning about RIP and OSPF but don't know how to use it very well and imagine that could possibly get things working.
