GLBP configuration
brijendrasaini
Dear Team,
As i configured GLBP on cisco 2960 it is possible to configure on this router.Am not able to ping vlan ip from one router to another how can i perform all these things.
All configuration is attched in word file
Julio E. Moisa
I suggest change to 2 the RIP version.
router rip
version 2
Im not really sure if the Cisco 2960 supports GLBP. but you can try using like you do with HSRP. Example:
interface vlan 10
glbp 10
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
7 Replies 7
Julio E. Moisa
router rip
version 2
interface vlan 10
glbp 10
Hi julio,
Not working glbp (Solved)
But why i am not able to ping vlan ip from both router....routing issue due to that ?
Thank you, was the RIP version to 2? also you can execute show ip interface brief in order to see if the SVI is up up or up down.
hi julio,
i changed the version also but not pinging.
#show ip interface brief
GigabitEthernet0/0 unassigned YES unset up up
GigabitEthernet0/1 unassigned YES unset administratively down down
Serial0/3/0 10.10.10.2 YES manual up up
Serial0/3/1 unassigned YES unset administratively down down
Vlan1 unassigned YES unset administratively down down
Vlan100 192.168.1.2 YES manual up down
regards
Brijendra
Ok the SVI 100 (interface vlan 100) is UP Down, it is generated becase the VLAN 100 is not associated to any port.
Usually on routers it is used when you have EtherSwitch HWIC modules so you can assign a VLAN on the port as you do on the switches.
I think your Interface Giga are not able to be associated to a VLAN. But I think Packet tracer has etherswitch modules to include on the routers.
hi julio,
thanks after inserting the module am able to ping the router 2 vlan
perfect  :-)
