Global to VRF NAT Problems
james-worley
I am using a 1841 running IOS 'c1841-adventerprisek9-mz.151-3.T1.bin'. I have two ethernet interfaces. One the WAN and the other the LAN. We use an Internet VRF to connect the WAN. Does anyone have any experiance with running NAT from a global interface to a VRF interface?
My config is as follows:
interface FastEthernet0/0
description *** Untrusted Public Network ***
ip vrf forwarding INTERNET
ip address 10.1.2.40 255.255.255.0
ip access-group WAN-IN in
ip access-group WAN-OUT out
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
ip verify unicast reverse-path
duplex auto
speed auto
no cdp enable
end
The LAN interface connects to the Global routing instance:
interface FastEthernet0/1
ip address 192.168.35.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim query-interval 10
ip pim sparse-dense-mode
ip nat inside
ip ospf cost 500
ip ospf 60 area 5
duplex auto
speed auto
end
Routing on each instance looks good:
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 10.1.2.1 permanent name Global_NAT_default_route
ip route vrf INTERNET 0.0.0.0 0.0.0.0 10.1.2.1 permanent name Public_default_route
The problem is when I try to browse the internet and resolve DNS queries. My NAT config looks like this:
ip nat inside source list LAN-NAT interface FastEthernet0/0 overload
Extended IP access list LAN-NAT
    10 deny ip any 192.168.0.0 0.0.255.255
    20 deny ip any 172.0.0.0 0.31.255.255
    30 deny ip any 10.0.0.0 0.255.255.255
    40 permit ip 192.168.35.0 0.0.0.255 any (162 matches)
I see nat translatiosn happening:
Pro Inside global         Inside local          Outside local         Outside global
udp 10.1.2.40:35992       192.168.35.21:35992   62.179.104.196:53     62.179.104.196:53
udp 10.1.2.40:40818       192.168.35.21:40818   212.142.28.68:53      212.142.28.68:53
udp 10.1.2.40:50020       192.168.35.21:50020   212.142.28.68:53      212.142.28.68:53
udp 10.1.2.40:50216       192.168.35.21:50216   212.83.68.131:53      212.83.68.131:53
udp 10.1.2.40:53440       192.168.35.21:53440   212.83.68.131:53      212.83.68.131:53
udp 10.1.2.40:54970       192.168.35.21:54970   62.179.104.196:53     62.179.104.196:53
udp 10.1.2.40:57031       192.168.35.21:57031   212.142.28.68:53      212.142.28.68:53
udp 10.1.2.40:54737       192.168.35.23:54737   62.179.104.196:53     62.179.104.196:53
udp 10.1.2.40:54737       192.168.35.23:54737   212.83.68.131:53      212.83.68.131:53
udp 10.1.2.40:54737       192.168.35.23:54737   212.142.28.68:53      212.142.28.68:53
udp 10.1.2.40:63199       192.168.35.23:63199   62.179.104.196:53     62.179.104.196:53
udp 10.1.2.40:63199       192.168.35.23:63199   212.83.68.131:53      212.83.68.131:53
udp 10.1.2.40:63199       192.168.35.23:63199   212.142.28.68:53      212.142.28.68:53
udp 10.1.2.40:63658       192.168.35.23:63658   62.179.104.196:53     62.179.104.196:53
udp 10.1.2.40:63658       192.168.35.23:63658   212.83.68.131:53      212.83.68.131:53
udp 10.1.2.40:63658       192.168.35.23:63658   212.142.28.68:53      212.142.28.68:53
udp 10.1.2.40:64366       192.168.35.23:64366   62.179.104.196:53     62.179.104.196:53
udp 10.1.2.40:64366       192.168.35.23:64366   212.83.68.131:53      212.83.68.131:53
udp 10.1.2.40:64366       192.168.35.23:64366   212.142.28.68:53      212.142.28.68:53
tcp 10.1.2.40:64577       192.168.35.23:64577   17.149.36.107:443     17.149.36.107:443
However my ACL see some funny looking traffic:
553814: *Feb 16 2012 11:14:23.974 CET: %SEC-6-IPACCESSLOGP: list WAN-OUT denied udp 62.179.104.196(53) -> 192.168.35.16(63590), 1 packet
553815: *Feb 16 2012 11:14:28.258 CET: %SEC-6-IPACCESSLOGP: list WAN-OUT denied udp 62.179.104.196(53) -> 192.168.35.23(53699), 1 packet
553816: *Feb 16 2012 11:14:37.089 CET: %SEC-6-IPACCESSLOGP: list WAN-OUT denied udp 62.179.104.196(53) -> 192.168.35.21(45487), 1 packet
For some reason the destination IP is showing as the source and the source inside address as the destination. If I remove NAT I see:
553775: *Feb 16 2012 11:07:29.182 CET: %SEC-6-IPACCESSLOGP: list WAN-OUT denied udp 192.168.35.200(3440) -> 212.142.28.68(53), 1 packet
553776: *Feb 16 2012 11:07:32.182 CET: %SEC-6-IPACCESSLOGP: list WAN-OUT denied udp 192.168.35.200(3441) -> 62.179.104.196(53), 1 packet
553777: *Feb 16 2012 11:07:49.700 CET: %SEC-6-IPACCESSLOGP: list WAN-OUT denied udp 192.168.35.21(41043) -> 62.179.104.196(53), 1 packet
Which is inline with what I would expect. I have had a play with the NVI feature but did not find a working config.
6 Replies 6
Eugene Khabarov
Level 7
Level 7
Hi! I think there is the problem only with WAN-OUT ACL. You should permit praffic from addresses in the NAT pool maybe?
Moreover you need to allow established connections in your WAN-IN acl.
In other way you need to inplement statefull firewall, f.e. ZBFW.
HTH. Please rate if it was helpful.
Hi Eugene
I'm pretty confident my ACL is correct. It was working before I moved the WAN interface into a VRF. But for the record my ACL is:
Extended IP access list WAN-OUT
    10 permit udp object-group Dirty-Interface eq isakmp object-group VPN-Hub eq isakmp
    20 permit udp object-group Dirty-Interface object-group VPN-Hub eq non500-isakmp (11300 matches)
    30 permit object-group Allowed-ICMP object-group Dirty-Interface any
    40 permit udp object-group Dirty-Interface eq ntp object-group Public-NTP eq ntp (1 match)
    50 deny ip 192.168.0.0 0.0.255.255 any log (34 matches)
    60 deny ip 172.16.0.0 0.15.255.255 any
    70 deny ip any 192.168.0.0 0.0.255.255 log (2031 matches)
    80 deny ip any 172.16.0.0 0.15.255.255 log
    90 deny ip any 10.0.0.0 0.255.255.255 log
    100 deny tcp any range 135 139 any log
    110 deny udp any range 135 netbios-ss any log
    120 deny tcp any any range 135 139 log
    130 deny udp any any range 135 netbios-ss log
    140 deny tcp any eq 161 any log
    150 deny udp any eq snmp any log
    160 deny tcp any eq 445 any log
    170 deny udp any eq 445 any log
    180 deny tcp any any eq 445 log
    190 deny udp any any eq 445 log
    200 deny udp any any eq syslog log
    210 permit udp object-group Dirty-Interface eq 27593 any
    220 permit tcp object-group Dirty-Interface eq 27593 any
    230 permit ip object-group Dirty-Interface any reflect IPtraffic (16073 matches)
    240 deny ip any any log (8 matches)
I use a lot of network-object (one of the best features of IOS 15 IMO):
object-group network Dirty-Interface
host 10.1.2.40
I still belive that it is correct behavior of the ACL and here is blocking rule:
Just for testing you can allow udp port 53 traffic and check for results.
No, I don't think it is. NAT should not be using original destination address as the source after NAT.
line 50 is blocks traffic that has not been NAT'd correctly.
Ok, according to the NAT order of operations, NAT will happens before outbound ACL check. I will look forward.
james-worley
I have now fixed this issue. I changed NAT to use the NVI interface.
