11-16-2005 03:37 PM - edited 03-03-2019 10:59 AM
My problem with tunnelling is as follows:
I need to create a layer 2 tunnel with an mtu of 1500 (normal Ethernet), as I
need to be able to tunnel PPPoE with a default MTU.
I have tried to create an L2TPv3 psuedowire for the tunnel. However the overhead
on the tunnel meant the PPPoE packets became too large.
To get around this I have tried running the tunnel over a GRE tunnel with the
mtu increased using the "ip mtu" command. This doesn't seem to work and packets
through the pseudowire seem to get invisibly dropped.
I am unable to increase the MTU on the network inbetween as the network is not
in our control. Are there any better ways of doing this that you know of?
The configuration I am using at both ends is like this:
pseudowire-class etherpw
encapsulation l2tpv3
ip local interface Tunnel0
interface Tunnel0
ip address 10.2.1.2 255.255.255.252
ip mtu 1600
tunnel source Loopback0
tunnel destination 87.248.130.11
interface Loopback0
ip address 87.248.130.10 255.255.255.255
interface FastEthernet0
description LAN Interface
no ip address
no ip redirects
no ip proxy-arp
speed auto
no cdp enable
interface FastEthernet0.102
encapsulation dot1Q 102
no snmp trap link-status
no cdp enable
xconnect 10.2.1.1 102 pw-class etherpw
I forgot to mention that the tunnel was working, but only when packets exceeded
an mtu of 1436. I use the "ip mtu 1600" to artificially increase packet size so
the L2TPv3 tunnel headers + contents of size 1500 fitted in the GRE tunnel. The
tunnel will still function with "ip mtu 1400", but not with the size of packets
we are using.
What do I need to do to get this working properly?
*Note that this is a personal issue not related to my day job.
thanks
Paul
11-22-2005 01:04 PM
mtu can be set in 2 ways either with a common "mtu" interface command and the protocol specific "ip mtu" cmd.
Changing the MTU value with the mtu interface configuration command can affect values for the protocol-specific versions of the command (the ip mtu command, for example). If the value specified with the ip mtu interface configuration command is the same as the value specified with the mtu interface configuration command, and you change the value for the mtu interface configuration command, the ip mtu value automatically matches the new mtu interface configuration command value. However, changing the values for the ip mtu configuration commands has no effect on the value for the mtu interface configuration command.So, better change the mtu size with the "mtu" command .This will automatically reflect in the " ip mtu" command .
