GRE Tunnel. Cannot get to other Network
pmarchant1
Hi all. i have successful configured my GRE tunnel and can ping the opposite ends of the tunnel from each side and even the router interface itself on the other lan.
My-Side
internal 192.168.0.0/24
Cisco Router 192.168.0.166 (F/E 0/0)
Tunnel 0 172.16.0.2
Main Network Router 192.168.0.0 > Necessary Ports forwarded and opened.
Their-Side
internal 192.16.1.0/24
Cisco Router 192.168.1.22 (F/E 0/1)
Tunnel 0 172.16.0.1
Main Network Router 192.168.0.1 > Necessary Ports Forwarded and opened.
From My-Side i can 172.16.0.1/2 AND 192.168.1.22 but nothing else on that LAN
From Their-Side i can ping 172.16.0.1/2 AND 192.168.0.166 but nothing else
<<<<<<<<<<Config from My-Side>>>>>>>>>>>>>
My-Side#sh running-config
Building configuration...
Current configuration : 1266 bytes
! Last configuration change at 09:15:44 UTC Fri Jun 8 2018
version 15.1
hostname My-Side
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2801 sn FCZ124712CT
redundancy
interface Tunnel0
ip address 172.16.0.2 255.255.255.0
ip mtu 1400
ip tcp adjust-mss 1360
keepalive 4 5
tunnel source FastEthernet0/0
tunnel destination <<THEIR-SIDE-IP>>
tunnel path-mtu-discovery
interface FastEthernet0/0
ip address 192.168.0.166 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 192.168.1.0 255.255.255.0 Tunnel0
logging esm config
control-plane
mgcp profile default
line con 0
speed 115200
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
<<<<<<<<<<<<<<<Their-Side>>>>>>>>>>>>>>>>>>>
Their-Side#sh running-config
Current configuration : 1208 bytes
version 12.3
hostname Their-Side
boot-start-marker
boot-end-marker
no logging console
enable password secret
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip ips po max-events 100
no ftp-server write-enable
no crypto isakmp ccm
interface Tunnel0
ip address 172.16.0.1 255.255.255.0
ip mtu 1400
keepalive 5 4
tunnel source FastEthernet0/1
tunnel destination <<MY-SIDE-IP>>
ip address dhcp
duplex auto
speed auto
ip address 192.168.1.22 255.255.255.0
duplex auto
speed auto
router eigrp 1
no auto-summary
ip default-gateway 192.168.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 192.168.0.0 255.255.255.0 Tunnel0
no ip http server
control-plane
line con 0
password security
login
line aux 0
password security
login
line vty 0 4
password security
login
line vty 5 807
password security
login
end
I have played as much as i can now and feel i am now just entering command to "just see if it works" and am out of ideas, Any and all suggestions/advice appreciated.
10 Replies 10
are these the full running configurations ? On your My-side router, you have only one local active interface, which is the tunnel source. Where is the local LAN configured ? On the other side, there is one interface that is getting its IP address through DHCP, I assume that is the LAN ?
Also:
are overlapping, you cannot use 192.168.0.0/24 on two different interfaces...
Hello
Your tunnel Scr/Dest addressing is you lan addressing which you using as the physical path for the tunnel creation.
res
Paul
Kind Regards
Paul
hi both, yes i am using the one interface on each router. i was shown this was many moons ago and is something we use here at my work.
Sorry not overlapping, my typo ! Sorry.....
Hello
That would be correct , you will need that one interface to create the physical path and logical tunnel, but then you will also require to have at least 1 additional interface (different subnet) on each router assigned to an internal network so it can be accessed via the tunnel.
res
Paul
Kind Regards
Paul
Ok. So I do need two physical connections even if they are in to the same switch.
My cisco router is not inline with the lan and the main outgoing router. It is plugged in with one cable in to the switch. I am sure I achieved all this before with one FE/ interface.
I assume then they have gotten away with by using vlans ? As you can gather I am still getting my head round this a bit at a time.
the tunnel sources (192.168.1.22 and 192.168.0.166) need to have IP connectivity at the very least, which they don't. What are you trying to accomplish with the tunnel ?
Yes they have internet connectivity and can ping 8.8.8.8 the remote site router and remote site tunnel end fine traffic just doesn't seem to get past the router at each end.
IE.
Myside can ping the 172.16.0.1 and 172.16.0.2 and 192.168.1.22 but then nothing else on that lan
their side can ping 172.16.0.1 and 172.16.0.2 and 192.16.0.166 but then nothing else on that lan.
Both routers can see internet and can ping 1.1.1.1 and 8.8.8.8 fine
Not sure if this helps or not ?
Hello
Looks like your Cisco router is a natted client to the isp rtr and you have created a gre tunnel originating from the internal Cisco router.
i am assuming you don’t have access to this isp rtr?
Even though your internal clients are all on a the same switch they still won’t be able to each the other side of the tunnel due to what I have previously mentioned -
However with a little bit of tweaking if you were to attach the switch to a spare interface on the the rtr in another subnet then you should be able to apply your own nat for internet access on this new private subnet  and also policy route over the tunnel for your site to site access.
res
paul
Kind Regards
Paul
it is unclear what your network looks like. Can you post a schematic drawing including all devices, how they are connected, and what IP addresses they are using ?
