GRE tunnel + PBR on cisco 2801
fmatrine
Hi All,
Can we configure GRE tunnel and Policy based routing on cisco 2801 router with IP Base IOS.
Kindly confirm.
royalblues
Level 10
Level 10
Hi friend
You can certainly configure GRE tunnel as well as PBR with an IP base IOS.
Use feature navigator to check the available features in a particular IOS
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
You should be good to go with IP base 12.4(11)T
HTH, rate if it does
Narayan
