GRE Tunnel
kmchoong
I have 2 routers, Marvin and champion. Both connected via Internet. But, Champion, 192.168.3.0 subnet does not seem to be able to browse Internet. Why?
Marvin Router
interface tunnel 0
ip address 10.1.1.1 255.255.255.0
tunnel source 203.1.1.1
ip nat inside
tunnel destination 219.11.1.1
tunnel destination 219.12.1.1
tunnel destination 219.13.1.1
tunnel mode gre ip
interface ethernet 0
description Internal Segment
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface serial0
description to ISP
ip address 203.1.1.1 255.255.255.252
encapsulation hdlc
ip nat outside
bandwidth 2048
ip route 0.0.0.0 0.0.0.0 203.1.1.2
ip route 192.168.3.0 255.255.255.0 tunnel 0
ip nat inside source list 110 interface serial0 overload
access-list 110 permit ip 192.168.3.0 any
access-list 110 permit ip 192.168.4.0 any
access-list 110 permit ip 192.168.5.0 any
Champion Router
interface tunnel 0
ip address 10.1.1.2 255.255.255.0
tunnel source 219.11.1.1
tunnel destination 203.1.1.1
tunnel mode gre ip
ip policy route-map gre
interface serial 0
ip address 219.11.1.1 255.255.255.252
ip route 0.0.0.0 0.0.0.0 219.11.1.2
route-map gre permit 10
match ip address 120
set default interface tunnel 0
access-list 120 permit ip 192.168.3.0 0.0.0.255 any
kmchoong
Sorry, the configuration should be as below:
Marvin Router
interface tunnel 0
ip nat inside
tunnel mode gre ip
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface serial0
description to ISP
encapsulation hdlc
ip nat outside
bandwidth 2048
ip route 192.168.4.0 255.255.255.0 tunnel 0
ip route 192.168.5.0 255.255.255.0 tunnel 0
Champion Router
interface tunnel 0
tunnel mode gre ip
interface serial 0
ip route 192.168.2.0 255.255.255.0 tunnel 0
Not applicable
It would be easier to answer the question and identify the problem if we knew a bit more about how you intend for this network to work. Usually when I see two sites connected through the Internet with a GRE tunnel, each site sends its own traffic to the Internet and uses the tunnel to get to destinations in the other site (allowing each site to use reserved (private) address space and still communicate over the Internet). But it looks like you intend Champion to send all of its traffic (including Internet traffic) through the tunnel to Marvin. Perhaps you could clarify this part?
Looking at these configs one of the important differences that I notice is that Marvin is configured with NAT while Champion is not. If you realy intend all Internet traffic from Champion to go through the tunnel to Marvin and then to the Internet, this would not matter. If Champion is trying to send anything directly to the Internet that is a problem.
I find some ambiguity in the configuration of Champion. If you really intend Champion to send all of its traffic through the tunnel to Marvin, then I would suggest that the default route on Champion should have as its next hop address the tunnel address on Marvin instead of having the ISP serial address as its next hop. That would also remove the need to have the Policy Based Routing which is trying to send everything through the tunnel. If you do change the default route to point through the tunnel then you will need to add a static route on Champion for the tunnel destination address:
ip route 203.1.1.1 255.255.255.255 219.1.1.2
If you are going to keep the Policy Based Routing to force traffic through the tunnel then I would suggest that you change the set clause. You really want to set the interface (or I might prefer to set the next hop) rather than the default interface). I suspect this is the major reason that Champion is not accessing the Internet in your current configuration.
Rick
Rick
