GUI tool for switchport
timhemmerich
Hey there,
I'm searching a tool with graphical interface for changing the configuration of different Switches. We want to create some kind of templates which can be selected and sent to a Port on specified Switch. We want to give this to our 1st level support because we don't want them to use CLI. Hopefully you can help me. I searched in the www but did not found a solution for this problem.
Kind regards
Tim
Mark Malone
the only one of my head is CNA did you come across that ?
http://www.cisco.com/c/en/us/products/cloud-systems-management/network-assistant/index.html
or else Prime but that's not free
Hi Mark,
thank you for your fast reply. I've tested this program but it has not the specification need.
I've also took a look at Prime but since we have a monitoring software this is too expensive.
But thank you again for your help and time.
Tim
