Guidance on modifying an ACL
Kevin Hamilton
Hello and happy weekend,
I have 4 VoIP hosts on the 7.7.7.0 subnet.  I only want them to talk to the upstream trunk server at 1.1.1.1 on port 5060 and the ACL (VERSION 1) below seems to work well.  However, now we are getting some DOS attacks against the 4 VoIP hosts on other ports from random various IPs.  So I need to block all traffic bound for the 4 VoIP hosts except port 5060 from 1.1.1.1, and not affect traffic bound for other hosts on the 7.7.7.0 subnet.  Can I accomplish my goal with ACL VERSION 2?  Any suggestions to modify the ACL below would be greatly appreciated.
Thanks Kevin.
VERSION 1:
access-list 101 permit udp host 1.1.1.1 host 7.7.7.7 eq 5060
access-list 101 permit udp host 1.1.1.1 host 7.7.7.8 eq 5060
access-list 101 permit udp host 1.1.1.1 host 7.7.7.9 eq 5060
access-list 101 permit udp host 1.1.1.1 host 7.7.7.10 eq 5060
access-list 101 deny   udp any host 7.7.7.7 eq 5060
access-list 101 deny   udp any host 7.7.7.8 eq 5060
access-list 101 deny   udp any host 7.7.7.9 eq 5060
access-list 101 deny   udp any host 7.7.7.10 eq 5060
access-list 101 permit ip any any
 VERSION 2:
#### First four lines explicitly allow traffic to my VoIP hosts.
#### Next four lines explicitly deny all UDP traffic to my VoIP hosts. Do I also have to specify TCP as well?
#### This line allows all other traffic to all other hosts.
Correct?
Richard Burts
Kevin
Perhaps Julio sees something differently than I do or understands something differently. But I do not agree with his statement that your proposed second ACL should work to accomplish what you want. I go back to your statement in the original post of what you need to accomplish "So I need to block all traffic bound for the 4 VoIP hosts except port 5060 from 1.1.1.1" Your proposed change in the ACL will block UDP but not any other type of IP traffic (not tcp, not icmp, not IPSEC, etc). I would suggest that changing the deny statements as I will suggest would accomplish your goal
access-list 101 deny   ip any host 7.7.7.7
access-list 101 deny   ip any host 7.7.7.8
access-list 101 deny   ip any host 7.7.7.9
access-list 101 deny   ip any host 7.7.7.10
Rick
Rick
6 Replies 6
Julio E. Moisa
Yes it will work. Just verify if you need to open other UDP ports.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
Thank you for confirming my idea.
Kevin
Richard Burts
Kevin
Rick
Rick
Hi Rick,
After I posted my question I realized that just blocking UDP would not solve my problem. Thank you for further clarifying my issue and listing the required statements.
Kevin
Hi Rick,
I have a follow-on question.  I'm thinking I should insert the new deny statements at lines 55, 65, 75 and 85, then remove the old deny statements at 50, 60, 70 and 80.  Does that sound like a reasonable plan?
Kevin
10 access-list 101 permit udp host 1.1.1.1 host 7.7.7.7 eq 5060
20 access-list 101 permit udp host 1.1.1.1 host 7.7.7.8 eq 5060
30 access-list 101 permit udp host 1.1.1.1 host 7.7.7.9 eq 5060
40 access-list 101 permit udp host 1.1.1.1 host 7.7.7.10 eq 5060
50 access-list 101 deny   udp any host 7.7.7.7 eq 5060
60 access-list 101 deny   udp any host 7.7.7.8 eq 5060
70 access-list 101 deny   udp any host 7.7.7.9 eq 5060
80 access-list 101 deny   udp any host 7.7.7.10 eq 5060
90 access-list 101 permit ip any any
Kevin
Yes what you suggest would be a good way to change the ACL. The important thing is that the individual deny statements should come after the corresponding permit statements for individual hosts and come before the permit ip any any. Your approach would achieve this nicely.
Rick
Rick
